Old 04-30-2009, 09:38 AM   #1
stealthy '69
'69 Chevy SWB
stealthy '69's Avatar
Front sway bar Question
Has anyone used this sway bar on ebay? Item # is 160331430419
http://cgi.ebay.com/ebaymotors/1963-...Q5fAccessories
For $130 shipped, does this sound like a good deal or would I be better off with a name brand one from some where like brothers or other dealers? The same ebay dealer has a rear for $150 shipped.
stealthy '69 is offline   Reply With Quote
Old 04-30-2009, 09:46 AM   #2
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: Front sway bar Question
Looks like a good deal but the ends of the bar look squished and I am pretty sure that would not mount on our trucks however I am by no means an expert and could be totally way off base..
Of course it could just be a generic pic also..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 04-30-2009, 09:52 AM   #3
vasquezmrysvll
"the other guy"
vasquezmrysvll's Avatar
it looks like it comes with end links to mount to the controll arm. good deal. ccp has similar deals on the bay right now.
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE"
vasquezmrysvll is offline   Reply With Quote
Old 04-30-2009, 10:03 AM   #4
dan42
dan42's Avatar
If you end up getting it, report back and let us know how it worked - a lot of us would be interested.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 04-30-2009, 11:53 AM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
There isn't anything high tech about a sway bar. A 100 plus dollar bar won't be any better than a 20 dollar salvage yard bar with new bushings.
Old 05-01-2009, 09:26 AM   #6
stealthy '69
'69 Chevy SWB
What bars will fit these trucks as a bolt on. Or I guess a better way to word is, Bars from what other vehicles will fit as a bolt on? I know I've seen on here a mid 80's-early 90's IROC or Z Camaro bar will work on the rear. But what fits the front?
Old 05-01-2009, 09:57 AM   #7
Tx Firefighter
I wrote an article on just this subject. I included lots of pictures and description. You can find it in the FAQ section.
The easiest source of swaybars is off 73-87 models, half ton, 3/4 ton, even 1 tons, plus Suburbans. They bolt right on. The holes are already in your truck for it.
Lets face it, a sway bar is a big old 1 inch (or larger) piece of round steel. That's it, nothing special about it. They don't wear out. It's very sensible to get a used one from the junkyard (around here that will run you about 20 dollars). Then, the new bushings are available at your local part store. Moog sells real nice urethane bushings for right at 25 dollars for all the set.
So now, you are out 20 for the bar, 25 for the bushings, for a total of 45 bucks. You have a great sway bar and you have saved a lot of money in the process. As heavy as a sway bar is, it wouldn't suprise me if shipping one would cost more than a used one. Why buy new ?
Old 05-01-2009, 11:13 AM   #8
fdbdw
fdbdw's Avatar
I have this bar and wish I would have got one from a junk yard that bolts to the holes already in the lower control arm, the angle of the legs in the bar make it a pain to line up the end links, just my oppinion but I think a stock bar that comes in straight to lower contol arm vs. comming out at an angle is better fit for these trucks
fdbdw is offline   Reply With Quote
Old 05-01-2009, 12:23 PM   #9
kelsfine69
18 Till I Die
kelsfine69's Avatar
Are the 73-87 truck brackets the same as well? The frame brackets and the lower control arm ones? ...Is it a direct swap?
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 05-01-2009, 08:57 PM   #10
stealthy '69
'69 Chevy SWB
when using the 73-87 bars does it matter if it comes off of a 2 or 4wd model?
Old 05-01-2009, 09:04 PM   #11
Tx Firefighter
The brackets are exactly the same. It's a bolt on deal.
You will need a 2wd bar for your 2wd truck.
Old 05-01-2009, 10:08 PM   #12
stealthy '69
'69 Chevy SWB
great thanks for all the info
Old 05-02-2009, 01:55 AM   #13
BossHogg69
motor exploder
BossHogg69's Avatar
If you're after performance and are gonna get a junkyard one, get one from a 1 ton, they're bigger in diameter. (1.25" I believe??)
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
