64 front end
i'm using a 78 surburban cross member for my front end, everything lined up just fine, had to drill two holes. getting the steering box hooked up not working so well, any suggestions
Re: 64 front end
the easy way is to buy a power steering kit...
Captainfab on here has a cool set up he sells CAPT'S POWER STEERING BRACKETS or LILRED66 has the other style that are better built than most the ones you get from the regular vendors....... google the REZ power steering conversion, many places sell them, but Classic Parts is the least expensive I have found.... If I had it to do over I would use Captainfabs kit......might do it anyway ![]()
![]() ![]() Last edited by joe231; 04-30-2009 at 01:27 PM. |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: 64 front end
Thanks Joe
