04-30-2009, 04:39 PM | #1 |
Inner fender mount
Anyone know where I can get the inner fender mount for my 1955 2nd series cab. I need only one of the flat plates with the two studs that go in through the floor and mounts the inner fender from the firewall. I know I can make one just seeing if an original type can be had. Thanks, Ronnie
04-30-2009, 08:46 PM | #2 |
Re: Inner fender mount
try some of the site vendors like gmcpauls or brothers or Musclerodz, alot fo them have the aprts you are looking for
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
04-30-2009, 08:58 PM | #3 |
I have searched in several vendor catalogs and internet and can not find this piece. Emailed a few and was told it is not available. Thanks, Ronnie
04-30-2009, 10:47 PM | #4 |
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
05-01-2009, 08:49 AM | #5 |
No its the bracket in which that piece bolts to. I guess I will just use two bolts and tack weld them to a flat plate and grind some of the heads off the bolts to make them flatter. Here is a picture of what I am looking for.
05-01-2009, 12:21 PM | #6 |
just reminder any buying or sell in this tread will get it locked. as long as your look for vendors to get it from that is fine. i think your flat plate and grinding the heads off idea will work. if you go to a faster store they will probley have the low profile bolt like those
05-01-2009, 12:59 PM | #7 |
55 must be different?? My studs are just spot welded to the sloped part of the firewall/floor pan. Get some "elevator" bolts, they have very flat, thin and wide heads so they lay almost flat with the floor.
05-02-2009, 06:18 PM | #8 |
I was working on the cab today and looked closer at my mounts, they do have the plate, it is so crudded up and covered with the POR-15 it blended into the firewall. Guess I need to look closer before I make affimative statements....
05-05-2009, 08:08 AM | #9 |
tubbed55, do you still need ? This rig is going to leave my drive (SOON) one way or the other? Anyway if anyone has a need let me know
Tubbed55 free if you have the need, FYI you pay the shipping? LOL |
05-05-2009, 06:41 PM | #10 |
Tomb23 you have a PM...
