![]() Join Date: Nov 2007
I am wanting to replace my HEI wire that is ugly looking and spliced up. It gets 11.32 volts with the key on. It is spliced with a 700r4 12v, and that gets the same 11.32. My question is on the IGN Unfused part of the fuse box, Do I need to add a fuse of some sort ? I really dont want to clip a connector on the cab side of the fuse box, but the terminal is tied in with another fuse on the back of fuse box.I did check that terminal and it has 12.34 volts going to it. I cant seem to slide out the terminal so I can run the wire from the back of the box so its not noticable. What am I doing wrong ? Thanks in advance
72 C20 Longbed 05 1500 Z71 Last edited by sleepertruck72; 04-30-2009 at 06:23 PM. |
I am a Referee of life.
Re: HEI wire question
If I understand what you're asking.There is a small bolt(5/16ths I think) in the center of the firewall side of the fuse block.Remove it and you can unplug the underhood connectors.I would find a good terminal to hook the 700R4 wire to.Then the wire that originally ran to the ignition can be rerun.There is a connector in the plug that can be taken out and replaced.Connect a new wire to it and run it as you want. then you will have a plug that looks stock and a wire that should have the full 12 volts for ignition.I'm not very familiar with the wiring on a 700 so maybe someone will chime in on that.The best write up I have seen on HEI wiring is by member shifty in the FAQ's section.It will give you the part # for the terminal that goes in the engine side of the firewall plug and also tells which wire it is.It's written for a 6 cyl but is the same.
Hope this helps some.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
Here is Shifty's thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=148346
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
Thanks PanelDeland, and Vettevet. Thats exactly what I will need for my 6 banger 67. I ended up messing with the fuse box until I got the connector out and was able to finally finish that up with a spare fuse box for connectors. Now my tranny and HEI have the 12volts they should. The way the PO had the wires hacked up was really strange. It worked but I ended up cutting off his puny 14 ga. wires and used 10 ga. The HEI previously had 11 volts as did the tranny. They worked, but now their happy with 12v The funny thing is, all this work was done because I changed my heater core, so I ran my spark plug wires behind the headers, hooked up those new wires for the tranny and HEI and I almost stripped and painted the inner fenders. Good thing I talked myself out of it
72 C20 Longbed 05 1500 Z71 Last edited by sleepertruck72; 04-30-2009 at 11:53 PM. |
I just used a female spade wire end and 10 gage wire hooked to the terminal you described. I run my fuel pump to the other one. You don't need it fused and I don't see any reason to hack into the fuse block.
I folded the original ign wire over and taped it into the harness but that isn't really the best idea and I'll fix that when I do some other wiring work in the engine compartment. I've run the HEI this way for over six months and it is one of the best things I have done on the truck. |
