Old 04-30-2009, 06:28 PM   #1
ihatericeburners
ihatericeburners's Avatar
Pulleys, what is going on?
I bought the kit from Classic Auto Air, the Surefit system, they say it comes with everything you need except for the pulleys. So... I went today to the salvage yard looking for pulleys and couldn't seem to find one to work. I need a 3 groove crank pulley, and 2 groove water pump. I can't figure out why I have what I have on my truck. I hope one of you can tell me what I need and possibly what I have.
[Edited by Mod]
ihatericeburners is offline   Reply With Quote
Old 04-30-2009, 08:22 PM   #2
ihatericeburners
Re: Pulleys, what is going on?
REVISED:
If someone could tell me/show me with pictures, what the original pulleys look like off a factory air motor, so that i am able to try to locate what i need.
Old 04-30-2009, 08:38 PM   #3
67ChevyRedneck
67ChevyRedneck's Avatar
It looks like you already have the correct "inside" pulley on the crank. The lower crank pulley against the balancer should be a "double" as well and your double pulley will bolt inside of that. There is also a double fan pulley.
Hopefully someone can back me up on that... but here's a pic of mine (sorry it kinda sucks).
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 04-30-2009, 08:39 PM   #4
truckdude239
truckdude239's Avatar
i've never seen that kind of set up right there maybe tell us what motor and year truck u have
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 04-30-2009, 08:42 PM   #5
Sinister
Between Trucks...
Sinister's Avatar
Here's mine, factory AC not hooked up. Your crank pulley looks right. Your brackets look haywire.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 04-30-2009, 08:44 PM   #6
67ChevyRedneck
Found a better pic for you:
When I go to add my power steering someday, I'll have to buy the lower crank pulley that bolts inside the double crank pulley I already have. Hope this helps.
Jesse James
Project "On a Dime"
Old 04-30-2009, 09:10 PM   #7
ihatericeburners
Thanks for the pictures guys, BUT i was looking at it more and if i were to get the 2 v groove water pump pulley then (yellow) then there is no pulley groove on th ecrank because of the gap (red).
So then where would i go from here?
Old 04-30-2009, 09:13 PM   #8
ihatericeburners
Oh. And about the temp bracket its on just till i can figure out where the p/s pump will be. ( i should have blured it to save myself the embarrassement).
Old 04-30-2009, 09:33 PM   #9
67ChevyRedneck
That's what I was saying you need a two groove crank pulley to fill that "red" space you drew.
Jesse James
Project "On a Dime"
Old 04-30-2009, 09:50 PM   #10
big_al_71
big_al_71's Avatar
Cool I see you went with the classic auto air set up.....can't help you with the pulley I went with the march pulley set.
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 04-30-2009, 09:59 PM   #11
ihatericeburners
Ok. (tinking).
so, i would then have 2 up on the crank the gap and then the 2, and then have the last one blank. And i am going to be able to find this item because i havent jet although i really havent looked at the 2/2 set up.
Old 04-30-2009, 10:30 PM   #12
ihatericeburners
Ya, I live an hour north of Tampa and they have a location there. they were going to ship it to my house for free but i need it here now. so i paid the difference and got it on a 2 day ride from texas. i had vintage in mind but when i called and talked to them thir coustermer service won me over. Also the fact that i was talking to them about the pulleys today for a good little while.
Old 04-30-2009, 10:33 PM   #13
ihatericeburners
If i cant find the 2 groove can i mate 2 single grooves together? they have that shaft-centric/ interlocking thing going on with them though.
Old 04-30-2009, 10:42 PM   #14
mr48chev
mr48chev's Avatar
Ok remember that you need pulleys for a short water pump setup. the pulleys off a later setup probably won't work.
I never throw a pulley away off anything I junk out and it has saved my tailfeathers more than once. I don't know if I have the proper pulleys to take photos of or measure though.
Old 04-30-2009, 10:52 PM   #15
AustinScott
AustinScott's Avatar
MY truck is an 68 AC truck long water pump, it has 3 groove water pump & crank pulley Maybe this would help.
AustinScott is offline   Reply With Quote
Old 04-30-2009, 10:57 PM   #16
ihatericeburners
"it has 3 groove water pump & crank pulley"
then the middle groove on the water pump is blank? Correct?
Wait. i have a short water pump. um...
Last edited by ihatericeburners; 04-30-2009 at 10:59 PM. Reason: new info on above pic
Old 04-30-2009, 10:58 PM   #17
AustinScott
[quote=ihatericeburners;3287231]
YES!, it connects to nothing, only the outer and inner groves on the water pump have belts
Old 04-30-2009, 11:01 PM   #18
mr48chev
mr48chev's Avatar
Transdapt shows black and chrome pulleys for short waterpumps with two grooves and the ac pulley for the crank.
http://www.tdperformance.com/
Page 74 in the 2007/2008 paper catalog on my lap.
Old 04-30-2009, 11:03 PM   #19
ihatericeburners
Thanks for the pictures and the info. I got to work in three hours so i got to pack this up and hit the hay.
Old 04-30-2009, 11:09 PM   #20
67ChevyRedneck
Jeez! How many different set ups did GM use???
Jesse James
Project "On a Dime"
Old 04-30-2009, 11:09 PM   #21
mr48chev
mr48chev's Avatar
You might check with these guys
AUTOMOTIVE ENGINEERING
5118 US Highway 19
New Port Richey, FL 34652-3942
(727) 848-8432 Phone
(727) 842-2477 Fax
They are supposed to be a dealer or check with ORiely auto parts especially if they are one of the speed parts stores.
Old 04-30-2009, 11:09 PM   #22
Livrat
Member #1049
Livrat's Avatar
you need one that looks like this for the crank..
http://cgi.ebay.com/ebaymotors/SMALL...Q5fAccessories
And one that looks like this for the water pump.
Livrat is offline   Reply With Quote
Old 04-30-2009, 11:13 PM   #23
67ChevyRedneck
^Those are what I have on my truck.
Jesse James
Project "On a Dime"
Old 05-01-2009, 08:26 PM   #24
ihatericeburners
5118 US Highway 19
(727) 842-2477 Fax
I called them and they want to sell me a march set up Or a billet one. I cant spend that kind of coin on a set up and then need to replace the water pump to a long pmp. They just sell the catalog parts, they couldnt offer any troubleshooting/ penny poor guy out. BUT they were very nice and friendly!
Old 05-01-2009, 08:34 PM   #25
ihatericeburners
OK! i found a 3 groove water pump pulley (no pics of the pulley yet). it looks correct! the only problem is that the diamater is going from 6.6 to 5 inch.
Is this going to spped up my water pump too fast?
THANK YOU to all of you who helped me out!
Last edited by ihatericeburners; 05-01-2009 at 08:35 PM. Reason: photo wasnt linked
