Lowering Block Kit- Will this work
Will this work on a 68 chevy c-10 that has coils in the rear?
http://www.jegs.com/i/JEGS/555/60802/10002/-1
1968 c10 Chevy 2005 Infiniti G35 2006 Subaru WRX STi ![]() |
Old member
Re: Lowering Block Kit- Will this work
Measure the pads and see. I think it's the right one.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Too many toys,not enough money
I don't think those are going to work. It say's for leaf springs, it will have locating pins that won't sit right with the axle mounts. The blocks you need are flat bar stock with 2 holes drilled in them. See my example below. These I made to fit mine. Also check in the FAQ's I know there is a post in there on how to build them. Cpp, EEC, Perhaps Bell Tech may sell the right kits.
Old member
My bad. I started typing before reading it good, sorry. They want work
MT71c-10, Thanks for showing me the right answer!. ![]() ![]()
No problem, Just trying to help!
From everywhere I was checking I couldn't find a full kit for them. I'd rather just pay a little more than having to drive from place to place and get u bolts made and 3" tube bar cut... oh well!
Thanks!
Just check with some of the aftermarket supplyers. Block kits are made for these trucks.
