Old 04-30-2009, 09:44 PM   #1
70Custom10Nut
70Custom10Nut's Avatar
Question steering column issues
I've asked before, does the spring on the top end of the steering column go on under the canceling cam or on top? I'm dealing with an aftermarket steering wheel hub that worked well on my non-tilt column, but doesn't seem to go on far enough. I have already made sure that it is seated and adjusted where it's supposed to be. Also, how do I get the horn contact plunger out so I can replace a weak spring? Does it require a special tool? Any advice would be great. Thanks, Cnut
70Custom10Nut is offline   Reply With Quote
Old 04-30-2009, 11:23 PM   #2
KevsClassics
TILT COLUMN GURU
KevsClassics's Avatar
Re: steering column issues
Spring first then cancell cam. Horn plunger can be removed by grabbing plunger with pliers and gently pull it out red retainer should come off with it. then replace spring then install plunger and slide retainer on and snap it in place
Instagram
kevs_classics64
64 Impala SS Conv
72 Blazer 2wd
75 Jimmy 2wd
63 Belair wagon
02 Silverado ext cab. DD
RIP EL JAY
KevsClassics is offline   Reply With Quote
Old 05-01-2009, 08:25 PM   #3
70Custom10Nut
On the plunger, does this go for a tilt column? I tried to gently pull it out and it wouldn't come out. I trust what you say but I have a habit of applying too much pressure in some situationsif you know what I mean. Cnut
