Old 05-01-2009, 08:38 AM   #1
jthornton
jthornton's Avatar
Posi
Hey guys i for sure want a posi or limited slip
whats the cheapest way i can go limited slilp or posi? is welding the spider gears the cheapest way haha
jthornton is offline   Reply With Quote
Old 05-01-2009, 08:48 AM   #2
my67chevytruck
Under Construction
my67chevytruck's Avatar
Re: Posi
welding the spider gears will be the cheapest, but typically dont last long, and wear the tires irregularly... from my past experience. I would say the best route to take would be an aftermarket limited slip setup, or a good used one.......
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 05-01-2009, 09:14 AM   #3
cdowns
cdowns's Avatar
Re: Posi
welding spiders is the way to go if you're entering it in a demo derby
otherwise buy something good and you can have your rear setup for a bit over a thousand dollars
Old 05-01-2009, 09:21 AM   #4
LONGHAIR
Re: Posi
Please, don't do this. Welding spiders is not only dangerous and destructive, it's just plain hard to drive on the street or anywhere else for that matter. It is hard to turn and makes the truck tend to "push" or "plow" instead of following the steering.
The "cheapest way" is to find yourself a used axle that already has the posi installed, with the gear ratio you need too. This is not necessarily the easiest way though. Finding what you need may take some leg-work, but it is a simple swap, once you do. There isn't much of a guarantee with this way though.
You can also go with an "add-on" unit like PowerTrax. It goes into your existing open differential in just about an hour or so, but you are stuck with the ratio that you already have....
You can buy a complete posi unit and have it installed. This is probably the most expensive way as far as cash up front, but you get everything exactly as you want, and a warranty from the installer.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
