Old 05-01-2009, 09:28 AM   #1
bw4sale
bw4sale's Avatar
Changing out my towers
My '68 was originally a 6 cylinder that someone put a 305 in. They used the 6 cylinder towers so the engine sits back too far. I know some guys like it this way and say run it like that, but it bugs me. So, I'm thinking of picking up some small block towers and doing it right. The question is will I have to change anything else? i.e. Trans crossmember or shift linkage. Will my driveshaft be too short, etc? I'm currently running a 3 speed, but would like to find a 4 or 5 speed that would fit.
BRENT
-'68 Stepside Project
-'98 Z71 Daily Driver
-Enough extra parts to build another truck and a half
bw4sale is offline   Reply With Quote
Old 05-01-2009, 11:52 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Changing out my towers
Yes, the trans cross member will have to be moved forward (there should be holes in the frame for the location). The shift rods and clutch rod will be too long and will have to be adjusted, and the drive shaft will be too short. You should be able to find a factory one the right length, it will probably be a two piece shaft. Throttle linkage will also be too short.
LockDoc
Leon
Old 05-01-2009, 12:01 PM   #3
bw4sale
bw4sale's Avatar
Really? For a short bed?
Shift Linkage isn't a problem because p.o. put a shifter in the floor. What about clutch linkage? I guess it is a different setup.
BRENT
Old 05-01-2009, 04:33 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
In reality, it sisn't worth the headache. I'm with you, I would rather see it forward where it belongs, but it just isn't worth it IMO.
Old 05-01-2009, 05:26 PM   #5
bw4sale
bw4sale's Avatar
That's disappointing. Has anyone had issues with cooling on a small block on 6 cylinder towers? The way it is right now, the fan is not even close to being in the shroud.
BRENT
Old 05-01-2009, 05:34 PM   #6
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
the 6 cyl and sb towers are the same. just in different locations. Forward for the sb and back for the 6.
LOW DOUGH is offline   Reply With Quote
Old 05-01-2009, 07:30 PM   #7
Longhorn Man
the 4 wheel drive trucks had the small block bach where yours is now. You could either get a spacer to push the fan forward (not recomended if you have a fan clutch) or source a 4X4 shroud
Old 05-01-2009, 07:44 PM   #8
Shyguy
Junior Member
Shyguy's Avatar
Or run an electric fan setup. Electric fan setups can be found by doing a search.
Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 05-01-2009, 10:03 PM   #9
LockDoc
LockDoc's Avatar
My experience is that they are not the same. If you use the 6 cyl towers in the forward position you will have to re-drill the bottom holes...
LockDoc
Leon
Old 05-02-2009, 10:55 PM   #10
RCbowtie69
RCbowtie69's Avatar
my truck was a 6 now a 8, motor is in the 6 location no problem over heating with 3 core radiator,plans to put it were the 8 should be, with a tremec transmission 5 speed check out there wed site, www.americanpowertrain .com, i talk to them at at auto fair in N.C. they have every thing to put in our trucks, most orders are ship within 48 hours, just check the site
RCbowtie69 is offline   Reply With Quote
Old 05-03-2009, 06:20 AM   #11
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
They are definitely different. I have piles of each in my shop. Similar, but not quite the same.
Old 05-04-2009, 08:48 AM   #12
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
oh,
Kevin, you got some pics to show the difference. I really thought they were the same. For the sb and 6.
Old 05-04-2009, 09:30 AM   #13
bw4sale
bw4sale's Avatar
Yeah, pics would be great.
BRENT
Old 05-04-2009, 12:02 PM   #14
Tx Firefighter
Here are pictures to illustrate the differences.
The I6 stands obviously go in the three rear holes. When you try to move them forward, only two of the three holes line up. You have to drill the third one.
When you use the proper SBC frame stands, all three holes line right up in the forward position without drilling anything.
You can obviously make either one work in either position, but to do it right, with no modifications, the proper stands are needed.
Old 05-04-2009, 12:14 PM   #15
LOW DOUGH
I'M TRUCK CRAZY!
LOW DOUGH's Avatar
They are definitely not the same. Thanks for the pics. This should help people out.
Old 05-04-2009, 12:14 PM   #16
steelhorse
steelhorse's Avatar
The truck should handle better with the motor in the rear position.
steelhorse is offline   Reply With Quote
Old 05-04-2009, 12:25 PM   #17
bw4sale
bw4sale's Avatar
Thanks for the pics, Tx.
BRENT
Old 05-04-2009, 12:26 PM   #18
bw4sale
bw4sale's Avatar
The other obvious difference is that sb towers are considerably dirtier than I6. Can't believe no one mentioned that.
BRENT
Old 05-04-2009, 06:04 PM   #19
michael bustamante
michael bustamante's Avatar
thats true mine are filthy but the inline 6 ones sitting in my garage havent gatered any oil covered dirt in years!!
1967custom
michael bustamante is offline   Reply With Quote
Old 05-04-2009, 08:10 PM   #20
oldiron
Designated Grumpy Old Man
oldiron's Avatar
I guess thats why my engine sits up so high and back so far in my 4x4. Can't even get a stock air filter on as it hits the firewall.
oldiron is offline   Reply With Quote
