Old 05-01-2009, 11:46 AM   #1
tomtuna1978
ac evaporator question
sorry if this has alredy been asked, i did a search... manny searches, and came up with nothing. i read someware that someone converted their factory air evaporator to a orface tube design from a newer truck, like an 87 blazer or truck. my question is how hard was this and what year and model evaporaror are you using? thanks for anny help... i just got a 69 c10 long bed and it has factory air and id like to do ths mod as i know the orface tube system like the back of my hand and can get it blowing ice out the vents
tomtuna1978 is offline   Reply With Quote
Old 05-01-2009, 12:16 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: ac evaporator question
You are talking about a POA upgrade kit. It is used with the factory evaporator coil. Here is what it looks like. It will not make your A/C system blow any cooler than the original POA valve.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 05-01-2009, 01:30 PM   #3
Lugnut64052
Middle-aged Curmudgeon
Lugnut64052's Avatar
I'm planning on re-making my system into a CCOT setup when I get the air going. Mosesburb figured out the parts to use in his excellent build thread.
Evaporator number is an ACDelco 15-6249. Long GM number is 3035171. It fits '77 Montes, Chevelles and Impalas. According to mosesburb it lays right in there but is a row or two shorter, so you'll have to fab a small bracket to weatherstrip it properly.
Accumulator number is ACDelco 15-1648. Fits many late '80s & early '90s mid-sized sedans.
Question back to you-- what are you planning to use for a condenser? The factory one or a different shape/style?
Bret
Check out the site's Truck Tech FAQ.
Be a site supporter.
My more-or-less pathetic build thread.
Board members I've met:
Longhorn Man
Dieselwrencher
jholley
big mike71
Lugnut64052 is offline   Reply With Quote
Old 05-01-2009, 06:38 PM   #4
tomtuna1978
i was thinking of using like a 95ish 1500 truck condencer because it is all reddy for 134
Old 05-01-2009, 06:55 PM   #5
john
member #16
john's Avatar
Heres a link to the orifice upgrade kit. http://www.oldairproducts.com/catalo...00_407_4071972
john is offline   Reply With Quote
Old 05-01-2009, 07:01 PM   #6
tomtuna1978
ok guys ... lets get this strait... i dont want to upgrade the old poa valve... i want to convert to a orface tube evaporator.
Old 05-01-2009, 07:24 PM   #7
Lugnut64052
Not sure what you're getting at . . . why would you keep the POA valve and install an orifice tube friendly evap?
Bret
Longhorn Man
Dieselwrencher
jholley
big mike71
Old 05-02-2009, 01:45 PM   #8
tomtuna1978
I don't want to keep the poa valve ... I want to convert the whole system to a orface tube system
Old 05-02-2009, 02:12 PM   #9
Lugnut64052
Okay, then the two part numbers I posted earlier will work. Surf over to mosesburb's build thread and look at the first picture in post #7. You can even see the orifice tube dimples on the inlet of that evap. The accumulator will screw right onto the outlet.
Bret
Longhorn Man
Dieselwrencher
jholley
big mike71
