05-01-2009, 01:54 PM | #1 |
Engine rebuild......350
I'm looking at rebuilding an engine for my '72. I'm going to send the block to a company and have it all prettied up and prepared for the rebuild.
I have been told that I should get some TBI heads, and that I can buy a rebuild "kit" and it would not cost me near as much as if I went out and bought all the goodies individually. Is this correct? And what's so great about TBI heads? I'm not looking to build something to race with, just something solid/dependable to drive for the next many many years to com. Opinions? Thanks, Greg |
05-01-2009, 02:10 PM | #2 |
Between Trucks...
Re: Engine rebuild......350
I've heard that TBI heads don't flow very well. Try some Vortecs.
Beat it to fit, Paint it to match... |
05-01-2009, 02:28 PM | #3 |
resident oilfield trash
Vortecs for sure
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada |
05-01-2009, 02:50 PM | #4 |
I would go with edelbrock aluminum heads but thats just my opinion. I have heard about the vortec heads as well.
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
05-01-2009, 03:39 PM | #5 |
I rebuilt my 307 with a set of vortecs. I put a mild 267/277 cam in it and those heads and its 30 over and it really wakened it up.
A computer once beat me at chess, but it was no match for me at kick boxing. Duct tape is like the force. It has a light side, a dark side, and it holds the world together. |
05-02-2009, 05:10 AM | #6 |
ENGINE BUILDER
What do you want? Performance? Economy? You need a PLAN!!!! Are you on a BUDGET? How much do you have to spend? TBI heads are easy to find but require a specific intake because the center bolts are a different angle. VORTEC heads flow a lot of air and make great POWER! They require specific rockers, valve covers and intake and a different alternator mount. Build a 383 stroker!
JIM ZAG |
05-02-2009, 11:33 AM | #7 |
GEARHEAD
If you have no experience building an engine or the proper tools, it will probably be cheaper and more dependable to buy a rebuilt plain jane 350. A rebuild using the original pistons and not doing any head rebuild or valve job will cost at least $450 to 500. If the bores are taper and it needs bored out, add about $100 for basic machining and another $200 for pistons (they need to be pressed onto the rods also. A valve job will probably cost another $150-200. This is assuming you don't have any other problems with any of the parts, and re-use valves, push rods, intake, front cover, oil pan, dipstick, etc.
I rebuilt a shortblock last month as cheaply as possible, and I'm re-using the heads and intake as is. I have all the required tools and spent about $450. I've done it a few times before, and I'm still hoping I didn't mess something up. I'm still running the 283 I built about 20 years ago, so I have reason to believe I did OK. There is lots of help and info available if you decide to do it. It's not that hard mechanically, just a lot of tedious measuring and fitting and cleaning, etc. Good luck, it's kind of full-filling knowing I did it myself.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
05-02-2009, 11:47 AM | #8 |
motor exploder
nothing is 'great' about TBI heads. they do make a great door stop though. A stock casting from 70-84ish will be your most economical (traditional intake & valvetrain parts), the vortecs offer great hp/$ but as stated above, require specific valvetrain parts and intake.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
