Cross member measurements
Does anyone have the crossmember and inner frame support measurements....or a box off there truck to go measure some thing for me? I'm doing a leaf to coil swap and thought there would be , at least a few bolt hole that would line up , but no such luck....and the manual is a bit deceiving in it's measurements. Thanks
#2 | |
resident oilfield trash
Re: Cross member measurements
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada ![]() |
the trailing arm holes are there, but not for the coil saddles or the cross member that holds the shocks , or the inner braces for the frame just in front of the shock cross member....damm i wish i still had that parts truck, i took some pics , but had to do it with the bed on ....and now they don't look as usfull as i though...
I can get you some pictures on monday make me a list of what you want to see
k will do .....i 'm hoping that somebody else will see this today to ....don't make a special trip though....if i have to i could get it this weekend if i make it to a wrecker
I am going to go over there monday any way I have to take this guy a qjet and get some stuff from him
hey 67 i'am looking for the measurement from the edge of the back cross member to the center of the shock cross member...and anything that ya can locate the inner portion of the frame supports..
![]() Join Date: Jan 2007
Powerbench I'm finishing the same swap with my 68' short bed.It's 42" from the end of the frame rail to the center of the cross member. When I was done I realized there is an oblong hole in the side of the rail that was dead center of the cross member.Everything came out good alignment wise on mine.I'm over removing rivets though.
1967 C20 Custom - 396/TH400 1968 GMC short step-350/M21 |
Thank you sir,i'll go out and see if this works when it stop raining around here..
