05-01-2009, 07:16 PM | #1 |
77 Suburban Parts on a 65 C-!0?
Hey all, Im still very new to these forums, and while I am pretty handy in the garage, my experience is lacking. I want to do the Disc Brake swap as I read here
http://67-72chevytrucks.com/vboard/s...d.php?t=209956 My Truck is a 65 C-10 Step-side Inline 6 with a 3 speed on the floor. I have located a possible donor vehicle 77 Suburban, will the "upper and lower control arms with the spindles attached" bolt right up like if it was a pick-up truck? In my head all the suspension and brakes should be the same maybe a little more beefier. Along with the the power steering, steering column, brake system, I will also want to drag the 350 and the Turbo 400 over maybe other bits as I look into it. Sorry if these are dumb questions, but I've never done something to this magnitude before I usually use the parts made for the truck on the truck. And while I know there are kits to do the same, this way seems a lot more economical as the amount of upgrades I can do basically for the price of 1 disc brake conversion kit. Thanks in advance for any tidbits ya throw to me. |
05-01-2009, 11:04 PM | #2 |
Re: 77 Suburban Parts on a 65 C-!0?
1/2 ton suburban?
the sub parts are the same as the trucks. everything should work no problem
CHEVY ONLY |
05-01-2009, 11:24 PM | #3 |
Shlong Bed Club
the power steering stuff would work too? i've got a '77 1 ton 4wd truck and i cant really use any thing off of it but the brake booster and master cylinder.
05-01-2009, 11:48 PM | #4 | |
60-66 Nut
05-01-2009, 11:53 PM | #5 |
it is my understanding that all you need for the 4x4 box to work is a 2wd pitman arm...the gear boxes are the same
dunno if the 1 tons are the same as the 1/2 tons though
CHEVY ONLY Last edited by joe231; 05-01-2009 at 11:54 PM. |
05-02-2009, 12:01 AM | #6 |
Shlong Bed Club
thats just my luck. i got that piece of a truck for the 350 in it and now i've decided to just build the 250 (more fun, but expensive) that truck is just gonna have to rust away behind the shop for now.
05-02-2009, 12:16 AM | #7 | |
60-66 Nut
And a litle tidbit of info, 2wd steering boxes (or just the sector shaft) are commonly swapped onto 4x4's when converting to crossover steering due to the 4 way keyed shaft.
05-02-2009, 04:25 AM | #8 |
Re: 77 Suburban Parts on a 65 C-10?
awesome, I was pretty certain they were built off the same platform just needed a little reassurance. Going by after work today to look at the possible donor. Thanks for the information
05-02-2009, 09:10 AM | #9 |
Keep It Simple Stupid.. Nope..
Shoot, send it my way.
1963 GMC SWB Fleetside in Sunburst Orange Metallic 305E V6 w/ Plaid VC, Powerglide, BOSS 313 20" Chrome Wheels, Kumho Ecsta STX 275/45/R20's, Alpine/Clarion System, Dynomax Exhaust Old custom classic trucks have soul. Their dashboards aren't plastic, and they've survived both the best and worst of what the 20th century had to offer. For the owners of these trucks, it's often the same story. Through both good and bad times they persevered, until one day they could turn the key and roll up in a customized truck everyone with good taste would admire. – Custom Classic Trucks |
05-02-2009, 11:04 AM | #10 |
good info John
CHEVY ONLY |
05-02-2009, 12:17 PM | #11 |
Resistance is Futile
I'll throw in my .02 also. From reading about these swaps, most run into issues with the idler arm mounting and you will need to fabricate or purchase an adaptor plate for mounting the power steering box. The other issue that others have run into is the tie-rod ends when swapping spindles. If you are using all stock stuff its not an issue at all.
I think using a donor vehicle is about the most cost effective way to put together a truck and its a great idea......'get it on!'
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
05-02-2009, 03:31 PM | #12 |
CaptainFab on here makes the adapter bracket you need to mount that steering box on your frame, and for almost half the price of the CPP version. See his related thread on here.
Chuck in Ohio *1962 GMC 1000 Panel Truck - 305D/Saginaw 4sp soon: 351C V6 + AX15 5sp OD trans, & 75-87/91 disc brake front end *1988 Suzuki Samurai 4x4 project, VW 1.9L mTDI, Toyota R151F transmission & Toyota full floater axles, LWB body tub stretch project *Many 1977-1979 Suzuki GS motorcycles, Kawasaki KDX220R, '77 Suzuki PE250, etc Last edited by Chuck78; 05-02-2009 at 03:31 PM. |
05-02-2009, 06:16 PM | #13 |
yeah and take lots of pics to share with us
CHEVY ONLY |
05-02-2009, 07:04 PM | #14 |
@protrash64
Thanks for the added info, I will keep that in mind, Im quiet certain all the stuff on my truck is stock, I will be sure to find out about the donor. @Chuck78 I have been eyeballing CaptainFab's adapter plate and will more than likely purchase one when I have my donor. @joe231 Pics will definitely be taken and shared Well the donor visit got postponed due to rain, till Tuesday |
05-05-2009, 06:31 PM | #15 |
Got the Donor. Ran pretty good on the way home cant wait to swap the 350 into the 65 too I angered the wife on the way home with it. I did a burn out and the muffler and tail pipe came off while She was following me. She avoided it, but I couldn't help but to laugh.
Now waiting for a couple days off work to do the swap. And I need to pick up some brackets from Captainfab Last edited by Boot; 05-05-2009 at 06:34 PM. |
05-05-2009, 07:24 PM | #16 |
is that a 3/4 ton Sub?
CHEVY ONLY |
05-05-2009, 08:26 PM | #17 |
Maybe... Did I screw up? Embarrassed how do I tell? Last edited by Boot; 05-05-2009 at 08:30 PM. |
05-05-2009, 08:35 PM | #18 |
not if you want 8 lug disc brakes, I don't know for sure but I think the 3/4 lower arm takes a different ball joint than the 1/2....someone on here will know
CHEVY ONLY |
05-05-2009, 08:43 PM | #19 |
05-05-2009, 08:53 PM | #20 |
yeah it is 1/2 ton if it is 5 lug....your all good
CHEVY ONLY |
05-05-2009, 11:39 PM | #21 |
60-66 Nut
Yep, that's the way to do it.....a whole donor rig. Now you have most everything you need to upgrade your '65.
