05-01-2009, 10:36 PM | #1 |
PROJECT 7DEUCE
67 and 68 or 69-72 that is the question
Heres the deal I have a 69 or 70 3/4 ton frame and 72 cab and bed with a 68 front wrap. I ordered the body bushings so long ago that I cannot remember what year I ordered and now that the sheet metal is on it appears the core support bushings are too tall? Any info or insight would be great here fellow board members..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
05-01-2009, 10:43 PM | #2 |
Re: 67 and 68 or 69-72 that is the question
IIRC, the '69-72 core support bushings are taller than the '67/68's.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
05-01-2009, 10:50 PM | #3 |
PROJECT 7DEUCE
Thats kinda what I figured with the fender gap im gettin at the bottom..... Anyone else wanna chime in before the full body suit and cut off wheel comes out...
05-01-2009, 11:29 PM | #4 |
its all about the +6 inches
I have the original 72 bushings under the 68 front clip on my 72 burb. Everything lines up fine.
05-02-2009, 06:57 AM | #5 |
Isn`t the difference just that 67/68 frames have smaller mounting wholes.I forgot what I knew on this,too.I think the question is,do you go by frame or core support?I`m doing a`67 on a`71,have bought bushings,can`t remember which,and not sure I got the right ones.I gotta start writting this stuff down.
05-02-2009, 07:17 AM | #6 |
Got the same problem, '72 Jimmy with a '67,'68 front end. Bottom of my fenders are off...from what I gather on the boards the '68 mounts under the core support should measure 1/4"-1/2", so I just plan to cut my '72 mounts down to that demension and super glue the metal washer back together
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
05-03-2009, 01:42 PM | #7 |
PROJECT 7DEUCE
I know the bushings I have are way bigger than 1/2 looks like the suit and cutting stuff is comming out.....
05-03-2009, 09:10 PM | #8 |
PROJECT 7DEUCE
TTT ONE MORE time
05-04-2009, 12:07 AM | #9 |
I just happened to be reading a FAQ post earlier today and noted the difference in the mounts. I saved a couple of pics as well. Maybe this will help.
The first two pics are of the 60-68 mounts and the last one is of the 69-72 mounts. |
05-04-2009, 12:17 AM | #10 |
Dumb question, but are you cab mounts correct? Isn't there a differencr with 1/2 and 3/4 ton?
72 Cheyenne Super 80 Silverado Blazer 2wd |
05-04-2009, 11:26 AM | #11 |
Project Junkie! Fishing Poor!!
Luke what I do when I run into the problem that you are having is to take loose all of the body mounts.
Jack up the front of the cab with the fender bolts loose. (This will close the gap at the bottom of the fender) While the front of the cab is still held up, tighten the bolts for the fender, then let the cab down. (repeat on the other side) Then I bring the whole cab and front end down evenly, snugging the rear cab bolts a little more than the fronts. The 3/4 ton body mounts are tall and are partialy the problem. The 67-68 core support cusions are the way they are because the hole in the core support frame bracket is smaller than the 69-72. The 69-72 core support bushings are made to recess into the larger holes of the 69-72 frame brackets. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
