Redefining LowBudget
flipped stock spindles???
Ok newbie dumb question??/
I was pulling my front end apart to bag it and was looking at the stock spindles.....Ummm it looks like you could flip them around to get about a 2-3" drop anybody ever try ??? I think if you put the left on the right and vise vera and flipped the steering arms around it may work.....yea I know it would be to easy........and cheap....... ![]() Jeff
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
Re: flipped stock spindles???
Go ahead and try it and let us know if it works....
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
GEARHEAD
Wouldn't the brake calipers be upside down?
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff |
Never Ending Projects
The upper and lower ball joint tappers are different sizes. Not going to work.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
yea the min I went back outside and looked I relised that.....
Official Site Guitar Shredder
aside from that...I would guess that the out tie tie rod s would be at a safe and crazy level.....?
I was thinking you could flip them over and it would make them level
LOL...aw hell I dunno..
we used to do it on 20's -30's cars with mixed results
laying low
![]() Join Date: Mar 2001
If I'm not mistaken you can flip the spindles on a 57 chevy car and get some sort of lift or drop. I like your line of thought there though.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
#11 | |
If you notice, the ball-joints do not form a vertical line between them, the upper is angled back at the top. Since the spindle is made to compensate for this.....even if it would fit on the tapers, the shaft would not be parallel to the ground anymore. It would tilt upward quite a bit.
Don't try it....
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
sorry I had my ass hat on instead of my thinking cap??
but I did get my bags in with less than impressive results...I guess I'll cut the lower a arm and put a slice in the upper to compinsate for the angle and see if that works....I wWANT MORE DROP and until I find some cheap drop spindles this will have to do...........
