05-02-2009, 07:16 PM | #1 |
Another Day, Another Dollar
truck "shuddering" under load in reverse
hey guys,
today while backing up my steep driveway i noticed some fairly intense shuddering coming from somewhere in the drivetrane. you could hear it as well as feel it. i am wondering if it is perhaps the U-Joint? 454 turbo 400 14 bolt full floater 4x4 35's any ideas?
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box "its hip to be square" |
05-03-2009, 04:36 AM | #2 |
Cheyenne Super
Re: truck "shuddering" under load in reverse
Was the engine lugging? if not maybe bad motor mount?
Is there a 'CLUNK' when shifting? |
05-04-2009, 11:08 AM | #3 |
Could be the trans. check your fluid. Reverse is usually the first to go.
I can still count my vehicles on two... wait three hands. |
05-04-2009, 02:26 PM | #4 |
Mine does the same shuddering thing in reverse, but I've got a standard. It shudders like crazy when I'm feathering the clutch in reverse under load. Like when I'm trying to back up a hill slowly. But since yours is an automatic, I'd check the fluid level and color. Could be the clutches starting to wear out.
05-04-2009, 03:33 PM | #5 |
Check the rear transmission mount. If it is broken, it will cause the trans tailshaft to lift up in reverse. That causes the pinion angle to be incorrect, thus causing a shudder.
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
05-07-2009, 09:11 PM | #6 |
fluid is good. mounts are good.
its slipping pretty bad now, im going to take it to the tranny shop in the next few days. i just had it rebuilt a few months back so i think (hope) its still under warrenty.
05-07-2009, 09:31 PM | #7 |
Robert Olson Transport
stupid question do you have a one piece drive shaft or a split one with the carrier bearing,, ive had bad vibrations from a bad carrier bearing
05-07-2009, 09:32 PM | #8 |
Converter?
1972 GMC C10 |
05-08-2009, 05:32 AM | #9 |
>130dB Moderator
Check the timing, steering column, and shift linkage.
Living Life @ 130dB LED Tail Light Conversion; How-to Friend. Father. Brother. RIP El Jay ------------------------------------------------------------------------------------------------------------------------- CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum. |
05-08-2009, 08:44 AM | #10 |
Junior Member
More than likely you are experiencing axle wrap and pinion preload. other than putting a four link in it not really to much you can do about it other than new stiffer leafs or adding a leaf. Sometimes your shocks can be worn out which helps induce it and putting on new shocks can help...
05-08-2009, 08:20 PM | #11 |
>130dB Moderator
Maybe add traction bars to solve the axle wrap issue?
05-08-2009, 11:20 PM | #12 |
the thing that really makes me laugh is that the bunny has two pancakes on it's head
1974 chevy Cheyenne C10 "The Mutt":4x4 convertion, NP208, 700-R4, stock 350, edelbrock Torker intake, edelbrock 600 CFM carb, duels 2001 Pontiac Grand Prix GT: 3.8L supercharged, 9.2:1 comprestion, ZZP XP cam, home made intake, 2 1/2" exhuast, 10psi of boost |
05-10-2009, 10:00 PM | #13 |
took it into the tranny shop.
they said the reverse band?? is slipping. anyhow i had it rebuilt in september and its still under warrenty
05-11-2009, 10:17 AM | #14 |
Junior Member
05-11-2009, 07:16 PM | #15 |
Sweet! Hopefully they are doing the R&R on the trans? I'd be pretty upset if I had to pull it out.
