Old 05-02-2009, 08:40 PM   #1
gintaras
I have a 12 bolt rear
Today I counted the bolts on my rear diff.. it's a 12 bolt. Is that something special? I KNOW it is not posi.. can I convert it to posi, or would it be best to buy a positraction rear end and swap it?
2004 VW R32 450 HP money pit (faster than a Viper in the 1320 )
2001.5 VW Passat beater
1972 Custom Deluxe Highlander 69k miles and counting, all original, even the paint
gintaras is offline   Reply With Quote
Old 05-02-2009, 08:47 PM   #2
The Big Green
Re: I have a 12 bolt rear
Yea, you can just buy a posi unit for it.
The Big Green is offline   Reply With Quote
Old 05-02-2009, 10:47 PM   #3
gintaras
thanks for the reply.
I don't know what ratio I have, so I jacked up the rear and turned the driveshaft by hand, but I only get about 1 and 1/2 turns from the driveshaft for one complete tire rotation.. I get the feeling that I need to multiply that by 2, so I assume I have a 3.08:1?
Old 05-03-2009, 12:59 AM   #4
5150.4.67
Pull the cover off and have a look. The numbers you are looking for are stamped on the ring itself. For example 38:10. This would be a 3.80 ratio. Now that you're this far, you might as well pull the axles and put in that posi!
5150.4.67 is offline   Reply With Quote
Old 05-03-2009, 09:13 AM   #5
JJanzen
JJanzen's Avatar
If you will look on the forward side of the passenger side of your rear axle, you will find a (3) digit code. It will be (3) capital letters. Once you have that code, go to this link and then "Axel Codes". It will tell your what your differential is. A lot easier than pulling the cover and counting teeth.
http://www.americanclassic.com/paint_test.asp
Blue72
Red72
JJanzen is offline   Reply With Quote
Old 05-03-2009, 09:29 AM   #6
LONGHAIR
That will tell you what was originally in there, but this is a 40 year old truck, it could be anything. Counting or looking for the numbers that are stamped into the ring gear itself are the only ways to know for sure.....it could use some new lube anyway, that is one of the most neglected things on any truck.
It's just not as easy as that. You really should have a Pro install something like that.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 05-03-2009, 10:23 AM   #7
WorkinLonghorn
WorkinLonghorn's Avatar
Yeah,you just multiply by two so if it is REAL close to 1 1/2 revs,then it's a 3.07-1 ratio (my book from 1969 doesn't show a "3.08" for these trucks).
To be sure,you can count the revs necessary for 10 revs of the wheel and divide by 5. This of course is with one wheel on the ground with an open (non-posi) rear.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent.
WorkinLonghorn is offline   Reply With Quote
Old 05-03-2009, 10:43 AM   #8
cdowns
cdowns's Avatar
converting with new parts posi carrier gearset bearings seals shims etc plus insallation labor runs $1200-$1500 if you can reuse the original axels
Old 05-06-2009, 12:49 AM   #9
5150.4.67
Correct, have it done by a pro. If you want it to last, that is.
