Old 05-02-2009, 08:53 PM   #1
skydiver
Just a fan.
skydiver's Avatar
Amp gauge going crazy...help.
Ok. This one is stumping me. When I start the truck the amp meter in the dash is stable and everything is fine. But when I turn on the turn signal, or hit the brakes, or anything else that draws a current, the needle on the amp meter starts bouncing from one stop to the other (waving at me). I have checked for continuity in the wires and all seems fine. The only thing I noticed is that the voltage out of the alternator fluctuates by 2V when the blinker is on. The alternator has been rebuilt. Does anyone have any experience with this? Any suggestions where I should look next?
skydiver
skydiver
1972 C10 Medium Bronze
skydiver is offline   Reply With Quote
Old 05-03-2009, 10:37 AM   #2
Wrenchbender Ret
Re: Amp gauge going crazy...help.
Sounds like a bad ground. Make sure you have a good heavy ground connection from the engine to the frame & the frame to the body. Check the connections at the junction block.
Wrenchbender Ret is offline   Reply With Quote
Old 05-03-2009, 11:48 AM   #3
cdowns
cdowns's Avatar
the way to check a grond is to take it apart clean both sides to shiny metal and put back together// looking at it does nothing
Old 05-04-2009, 05:30 PM   #4
skydiver
Just a fan.
skydiver's Avatar
Thanks for the tip. I will check all grounding points.
skydiver
Old 05-04-2009, 08:07 PM   #5
skydiver
Just a fan.
skydiver's Avatar
Just checked and cleaned the grounding at the engine and the body. Still have the problem. Wondering if it could be a bad battery now. Or bad alternator. Just had the alternator rebuilt last year and had them add a few more amps of power. Wondering if it is too much now. In a nutshell, amp gauge is bouncing back and forth and the headlights (when on) vary in intensity. Also, I think I am over charging the battery b/c when I kill the engine the battery is whistling (de-gassing?).
I am so not an electrical guy . Need some expert advice on this one. Has anyone had this problem before?
skydiver
Old 05-05-2009, 01:08 PM   #6
Bears63
...just another truck junkie..
Bears63's Avatar
I have seen this happen when voltage regulators go bad. Have you checked that?
Mike "Bear" Shea
Bears63 is offline   Reply With Quote
Old 05-05-2009, 02:50 PM   #7
VetteVet
Msgt USAF Ret
VetteVet's Avatar
I suspect you have a voltage regulator problem as well and have you checked the water level in the battery? If you have been overcharging all this time you may have boiled some water out of it and that would cause the fluctuations. How much voltage are you reading at idle at the battery with no loads on the system. It helps to know if you have the external regulator or the one inside the alternator .
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 05-05-2009, 07:52 PM   #8
skydiver
Just a fan.
skydiver's Avatar
I have an external voltage regulator and have replaced it already. Didnt stop the problem. The voltage I am reading at the battery with no load is about 13.7 volts. The voltage out of the alternator is about 14 but fluctuates from 13 to 15. I have a feeling that its the alternator. I had it rebuilt by a local shop and at the same time they bumped up the amps to about 75 from 60. Does anyone know if the output from the alternator is to be steady or varying?
skydiver
Old 05-05-2009, 08:22 PM   #9
Sinister
Between Trucks...
Sinister's Avatar
Just put a new internally regulated alternator in my truck and the output varys.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
