Old 05-02-2009, 10:28 PM   #1
Dapper Dan
Dapper Dan's Avatar
question about van rallies
I would like to run rally wheels and have been thinking about the van wheels for the front. http://baltimore.craigslist.org/pts/1151377952.html
I searched the site and found in a thread that they should have 3" backspacing. I'm not good with wheels and backspacing so I guess what I was wondering is will they sit far in the fender or will they still be near the edge
Also if the wheel is 6.5" wide with 3" backspacing does that mean I can measure 3.5" from face of rotor and that is where the edge of the rim should be? Thanks for the help
Dapper Dan is offline   Reply With Quote
Old 05-02-2009, 10:44 PM   #2
jdurant
Re: question about van rallies
The outer edge of the wheel would be 3.5", or 4" inches from the mounting pad of the rotor depending on how backspacing was measured. Because a 6.5" rally actually measures 7.5" from edge to edge. So your 8" rally should measure 9" wide.
Just so you know they did make a 7" rally, therefore it actually measures 8". And the extra 1/2" is on the outside. They are kinda hard to find, but I think that would make for the best combo. I think they were on some of the earlier trucks and I think I have seen them on a few vans. Supposedly all rally wheels are stamped on the inside with a size.
Joseph
87 Turbo Buick
92 5.0 Mustang coupe
87 GMC Sierra SWB
82 Chevy K5 Blazer 2wd
jdurant is offline   Reply With Quote
Old 05-02-2009, 11:02 PM   #3
Pyrotechnic
Pyrotechnic's Avatar
Sounds about right for a 6.5" wide wheel. Makes a good skinny wheel for the front if you are into that look.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 05-02-2009, 11:32 PM   #4
SCOTI
SCOTI's Avatar
Here's some 6.5" van ralleys on the front to give you an idea where they 'sit' vs. the outer fender-lip. The rears are 8" truck ralleys.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-02-2009, 11:36 PM   #5
jdurant
nice pic!
Joseph
87 Turbo Buick
87 GMC Sierra SWB
Old 05-03-2009, 11:33 AM   #6
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
on my 86 i had i did just that two skinny ones on front and two wides on on the rear and it looked fine,,
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 05-03-2009, 12:51 PM   #7
LONGHAIR
"Backspace" is the distance from the edge of the rim to the flat area where the wheel mounts to the rotor.....from the back side
"Off-set" is how far that same flange is away from the exact center of the wheel.
So a 6" wheel and an 8" wheel with the same backspace would have different off-set.
Her is a quick little diagram to show it better
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 05-03-2009, 12:53 PM   #8
Dapper Dan
Dapper Dan's Avatar
Thanks everyone Scoti that picture is just what I was looking for. I think I will go for them 30 bucks is cheap, and right now my rear wheels look narrower than the front something I want to change with the next set.
Old 05-03-2009, 03:12 PM   #9
Turbo85GMC
Turbo85GMC's Avatar
If you don't mind my asking, how much of a drop is that in the front? And what size tires?
'85 GMC 1500
"Friends don't let friends drive stock!"
Turbo85GMC is offline   Reply With Quote
Old 05-03-2009, 03:18 PM   #10
SCOTI
SCOTI's Avatar
Front is 3" Bell tech spindles w/1-coil cut from the stock V8 springs (lower a-arm requires trimming w/a 15" wheel) & 215-70-15's. The rear is a flip kit on a HD 8-leaf spring pack for a true 6" plus Bell Tech 2" shackles & 255-70-15's.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
