05-02-2009, 11:00 PM | #1 |
suspension drop and a-arm bumpers
Can anyone speak from experience about a 2" drop and the a-arm(upper and lower) bumpers? Do the originals work just fine or do they need to be shaved?
05-02-2009, 11:12 PM | #2 |
Tot Roddin'
Re: suspension drop and a-arm bumpers
I will have to let someone else answer this one, but I believe that with a 2" drop you will be find with the factory bumpstops.
I'm going to get this moved over to the suspension section for you as well, hopefully a few more responses for you over there.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
05-03-2009, 12:16 AM | #3 |
Designated Grumpy Old Man
Moving this for you.
Never let the truth get in the way of a good story 71 Chev 1/2 ton 4X4 LWB Fleetside SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=361222 http://www.youtube.com/watch?v=1LgREwtDfaA 68 Chev 1 ton flat bed http://www.youtube.com/watch?v=0bO8szzlD4A 56 Chev Handyman Wagon http://www.youtube.com/watch?v=9y-6ddpBTkM http://www.youtube.com/watch?v=lbLzZ7zY8wA 56 Chev Belair http://67-72chevytrucks.com/vboard/s...d.php?t=410667 http://www.youtube.com/watch?v=xoW0Ei7ZNIg |
05-03-2009, 06:09 AM | #4 |
Watch out for your cornhole !
The upper A arm bumpers don't matter on the drop. They are there to keep the suspension from overextending when unloaded.
On the lower bumpers, you will be fine with a 2 inch drop. After driving it a few weeks, you might look at the bottom of the crossmember where the lower bump stops hit it. If you see a shiny spot in the grime, you can know that the snuber has been hitting it, and you can trim accordingly if needed.
05-08-2009, 07:19 AM | #5 |
One day.....
TX couldn't of said it better.
DZL1. |
