05-03-2009, 03:46 AM | #1 |
Gettin It One Pice At A Time
oil pan off-inspection
hey, in a few days I am thinking about taking the oil pan off and taking a look at the lower end of my motor. is there anything that I can look for that will show how the motor is, health wise?
RIP ELJAY Work In Progress 1979 GMC C1500 Trailering Special. Getting the truck done, one piece at a time. “You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan “I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby |
05-03-2009, 04:45 AM | #2 |
Cheyenne Super
Re: oil pan off-inspection
Unless you already have the engine out, or need to change the seals anyway
I don't see any reason to take it appart, if it ain't broke... Silver oil, low oil pressure, clicking, knocking and tapping are better signs of engine wear. I do however double check a few things after getting one back from a rebuilder. |
05-04-2009, 05:11 PM | #3 |
If you're gonna have the pan off anyhow. Run a couple Plastigages around the mains and rods to check bearing wear.
That's if you REALLY wanna scare yourself. - Dave
2003 Silverado K1500 Z71 - Arrival Blue 1973 K5 Cheyenne Blazer 350/TH350/NP203 Kids Trucks:92 K1500 Blazer 5.7/700R4 4" lift. RETIRED: 1980 Scottsdale 4x4 Founding Member: "TILT WHEEL BELLY." Club |
05-05-2009, 06:57 AM | #4 |
Check the oil pickup screen on the pump. They get deposits and sediment on them and can inhibit oil flow to the pump. Tap the pan bolt holes back to flat if the bolt holes have been pulled into the gasket. Sounds like a great time to change the timing chain, just a few more bolts to take off if you already have the pan down.
05-05-2009, 07:50 AM | #5 |
I wouldn't take it off unless you have some other reason to. You are starting a snowball.
82 Chevy SWB "OrangeAnimal" Lot of Goodies! Sold 93 GMC 1500 "Angry Red" 383 TBI Powered Fun! 300hp/410ft.lbs. 09 Yaris wife's daily. |
05-05-2009, 04:28 PM | #6 |
05-05-2009, 09:16 PM | #7 |
well I was told years ago by a old-timer mechanic that there was rod knock when it started up. just thought if you could see if that true if took the pan off. but at this point. right now I should keep it, " here no evil, see no evil". lol my plans for the future is to rebuild the motor anyway.
05-05-2009, 09:22 PM | #8 |
If you can't someone knocking at the door do you go check anyway?
There is my metaphor for the day.
