05-03-2009, 10:42 AM | #1 |
Small cap distributors, block huggers
For those of you who have changed your 6 to a small block what small cap distributor have you used and what brand of block hugger headers worked for you, BTW I am doing a 62 truck, Larry
05-04-2009, 12:18 AM | #2 |
Resistance is Futile
Re: Small cap distributors, block huggers
Any type of block hugger will work; it will have a tite corner if you use the front mounting position for the engine, however. Long tube and shorty headers are a different story.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device Last edited by protrash64; 05-04-2009 at 12:18 AM. |
05-04-2009, 12:20 AM | #3 |
60-66 Nut
I've always used the large cap HEI's on the '63-'66's with no problems with clearance.
05-04-2009, 12:14 PM | #4 |
I am using a large cap H.E.I. as well. Its tight but it fits. I also am running block huggers with no clearance problems.
1964 Chevy C10 a.k.a. Julie Ann H.E.I. cause its better to be pointless |
05-08-2009, 02:56 PM | #5 |
Thanks for the help, I'll try the large cap back before I give up, cheers, Larry
