Old 05-03-2009, 03:20 PM   #1
GMC406
Professional Grade
GMC406's Avatar
What is the best way to fix front shock mounting holes?
I will have the eng out in a few days and what to address a prolem that has been troubling me for years. The front shock bolt holes are rusted out and way to big. The head of the bolt just holds the shock in at the top of the hole. One person told me I can just take 2-3 heavy duty large washers with the correct ID for the shock bolt and weld them together then to the frame. That would be simple but I dont know if I like that Idea. If anyone else has any better sugestions let me know. Maybe some of you have experianced this same thing?
61 GMC 9' Step
Someday it will be a build http://67-72chevytrucks.com/vboard/s...=1#post3356828
67 C-30 Red Dale motorhome http://67-72chevytrucks.com/vboard/s...31#post3845531
71 GMC Street performer in the works
Waiting for warm weather
http://67-72chevytrucks.com/vboard/s...d.php?t=341946
1990 GMC Sierra GT-sold
1983 chevy 4x4-project on hold maybe sell
1969 Triuph GT 6- sold
1996 Ford I-6 5 Speed 4x4
2004 Dodge Intrepid- milage maker
1959 Ford Fairlaine, factory a/c 292Yblock- sold
1982 Honda XL500R
Always lookin for other old trucks!
GMC406 is offline   Reply With Quote
Old 05-03-2009, 04:21 PM   #2
cdowns
cdowns's Avatar
Re: What is the best way to fix front shock mounting holes?
i've always used heavy duty fender washers and welded it up
Old 05-03-2009, 04:28 PM   #3
WIDESIDE72
WIDESIDE72's Avatar
Nothing wrong with this fix that I can see. Not sure of any other ideas, as a matter of fact...Be sure your metal is clean in order to get good weld penetration.
WIDESIDE72 is offline   Reply With Quote
Old 05-03-2009, 04:38 PM   #4
Ace in the hole
what don't you like about the idea? I have used the washer idea several times and it works great.
when I had my truck torn down I had some thin rusted metal on two of my body mounts. I basically did the same thing, only I punched the holes out big enough to get back to good solid metal then found some big heavy washers that I could weld back into the enlarged hole.
1970 K20, 350--- SOLD
05 silverado extended cab short box- duramax
Jeep wrangler unlimited
Ace in the hole is offline   Reply With Quote
Old 05-03-2009, 04:43 PM   #5
GMC406
Professional Grade
GMC406's Avatar
Cool that should be a simple fix then, I figure 2 thick implement type washers on the inside and out should be plenty. I work for a oilfield company so we got plenty of choices for that at the shop. Thanks for the input, much apriciated.
61 GMC 9' Step
1982 Honda XL500R
