![]() Join Date: May 2007
correct np205 transfer case color ??
does anyone know the paint code or name of the color used on the NP205 transfer cases ? I know it is supposed to be a reddish-orange color because there is still some original paint on mine. Does anyone know of a VHT, dupli-color, PPG, Dupont, etc. code that may match ?
thanks, LUCKTRUCK 1972 chevy 4x4 shortbed |
Re: correct np205 transfer case color ??
rustoleum red primer is close
Mike Redpath |
like musclerodz said, red primer is a pretty good match
1970 K20, 350--- SOLD 05 silverado extended cab short box- duramax Jeep wrangler unlimited |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
chrysler red also....
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
I used Chrysler red on mine also.
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. |
thanks for the responses, I'll give those a try. Anyone else have suggestions ?
Born Psycho
![]() Join Date: Feb 2001
rustoleum rusty metal primer is a nearly perfect match
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
I used the chrysler red on mine just for the gloss factor, but the correct color is the red primer flat.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
This is what the rustoleum red primer looks like I used, also sprayed a clear over it to give it a little better seal and a little shine,
"85" Monte Carlo SS "71" K5 (SOLD) "64" Chevelle 1930 Chevy two door rat |
![]() Join Date: Apr 2000
mine looks like it was chevy orange
Wade "DURAMAX BURB" Burb on 2004 chevy 2500HD 4x4 Duramax chassis Long term project 2004 2500HD 4x4 crew cab GMC Duramax 4" lift 35's 79 RS Camaro Last edited by DINS 1; 05-04-2009 at 02:15 AM. |
Not unless someone had painted it prior.
Tim |
