Old 12-28-2002, 08:46 AM   #1
Steve Carda
Steve Carda's Avatar
Question Gas Guage
Everyone,
Been a long time! The board has changed soooo much since I've last posted! I bet I haven't posted in a year. I can't believe i've been too busy to check things out. Should never happen! Things look really great around the board lots of nice changes!
Question:
My fuel guage when the tank is full goes way over full. The guage stays there until the tank is almost empty and then drops to the empty mark. Sometimes while driving the guage will go to the normal reading position and then go to the way over full mark.
68 4x4 402 big block
Steve Carda is offline   Reply With Quote
Old 12-28-2002, 10:35 AM   #2
Blackhawkdc
440 american Horses
Blackhawkdc's Avatar
sounds like the sender inside the tank is getting corroded or just plain worn out.
Seth Petro
1969 Chev Short Step
425hp 350, TH400, big tires, fast truck
1979 Pontiac Trans Am
1991 Saturn SL1 - gas mileage! (and free)
1977 Buick LeSabre - for sale
May America bless God, and may God bless America
Blackhawkdc is offline   Reply With Quote
Old 12-28-2002, 10:36 AM   #3
Steve Carda
Thanks!
Old 12-28-2002, 07:56 PM   #4
da-burb
"Ochre Ogre"
da-burb's Avatar
Hey steve, was thinking of you again as I drove through NU this week. When you fix your gas gauge problem would you fix mine in the snow plow truck too? Exact same problem. Thanks!
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 12-29-2002, 01:16 AM   #5
Duallie
Duallie's Avatar
When a gas gauge reads "past full", that means there is an open connection. You have a poor connection or an occasionally-broken wire. Could be a bad ground or loose plug or dangling connector or a mashed wire.
Just as if I knew what I was doin'
Duallie is offline   Reply With Quote
Old 12-29-2002, 12:01 PM   #6
Steve Carda
Thanks for the help guys.
Hey da-burb hows things? I'm still workin on that 68. Needed to come back to the board to get motivated! I think of ya once an awhile when I hear your name around town.
Old 12-29-2002, 06:46 PM   #7
bmg
bmg's Avatar
Gas Gauge
I got a gauge with a new sender in but still goes way past full, but does work and moves down as i burn the gas up. I did notice that when it gets real cold the gage bottoms out to the full side then i turn the heater off it goes back to normal. What may be the cause of both these problems, all new wires in truck.
bmg is offline   Reply With Quote
Old 12-29-2002, 06:50 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
BMG, you need to ground your insterment panel better. I piece of wire going from the metal backing of the panel and run to the dash or pedal assembly oughta do the trick.
Old 12-29-2002, 07:04 PM   #9
71k5
I think it's a bad ground, too. It might be quicker to install new grounds: frame to eng; battery to body; truck bed to frame, etc. Let us inow when you find the fix!
71k5 is offline   Reply With Quote
Old 12-29-2002, 07:10 PM   #10
bmg
bmg's Avatar
Gas Gauge
This is a complete reconstruction everything is new.....that is what is so puzzling
Old 12-29-2002, 07:10 PM   #11
bmg
bmg's Avatar
Gas Gauge
i will try another ground.....
Old 12-29-2002, 07:39 PM   #12
Longhorn Man
Some times on a frame off, you'll get paint where two pieces of metal connect, and that had been used as a ground. Once the paint is insulating it, you don't get the proper current flow and it causes funny things.
