2-door hoe
bucking and surging at idle
80 full size k5 blazer 350 with no emission equiment on it at all. it has a holley 600 cfm carb eletric choke, petronix flame thrower dist. and coil.......................now to the problem this truck when at idle surges at a stop light, in drive it lerches the truck, if you then put it in neutral it stops or barly hold the gas down it will stop lerching....but the idle is not set to low and when its surging its not to low...now this morning while warming it up (btw hot or cold it does this) it was surging so i poped off the air cleaner (i had suspected the choke was stuck) and im just watching the engine rock from side to side so it messed with the air screws and the idle......nothing no change!! so i put it all back to where it was and here i am begging for your help........this is my girl friends truck and shes out beating the crap out of my truck untill i figure out this problem so help me swiftly please....sorry about my spelling
Re: bucking and surging at idle
It sounds like a mis. I would check the plugs and wires.
I can still count my vehicles on two... wait three hands. |
2-door hoe
brand new just did them. problem was there before i replaced plugs and wires.........im leaning twards carb or ignition problem.........drives great no problems at all under load or cruzing just at idle
Vacuum leak? God Bless, Terry
vacuum leak sounds right,check hose or cap at back of carb and also if you are running a pcv valve make sure the other valve cover is sealed! if not it's a leak..run another breather and do away with the pcv,then re-adj. idle mixture screws.another note..poss power valve failure???ever backfire throuhg carb?? were the old plugs fouled??
#6 | |
2-door hoe
2-door hoe
im pulling out my hair and i was told that the torque converter may be to blame its a 700r4 thats in there is it possable that the converter is making it surge i unpluged the lock up plug and it was the same but i just dont think unpluging it will be a proper test
Kid's Mechanic
does the distributor have a vacuum advance?Diaphragm in it could be just starting to go bad and are the mechanical advance springs weak? also the power valve in the holley carb could have a pin hole in it and thats why the air jets make no difference.
2-door hoe
all possabilties bu tthe finger points at vacuume leak is that what im hearing?.........i just dont want to tear the carb apart if its a dead end
Pull the distributor cap off and test the vacuum advance for a leak. it is very possible that could be the problem. You can use a vacuum pump to test it or you can try and push the rod in then put a vacuum cap over the connection see it goes all the way back out. HTH.
82 Chevy SWB "OrangeAnimal" Lot of Goodies! Sold 93 GMC 1500 "Angry Red" 383 TBI Powered Fun! 300hp/410ft.lbs. 09 Yaris wife's daily. Last edited by OrangeAnimal; 05-05-2009 at 07:39 PM. |
#11 | |
2-door hoe
any info on this matter yet.im curious
