Old 05-04-2009, 11:56 AM   #1
SEAGATOR5
Need power window help
I got this 85 k10 about 4 months ago. The passenger side window moved up
and down very slow. When I replaced old window seal 2 months ago with new
one it would'nt move at all w/o help. I "assumed" the motor was just worn out.
This weekend I replaced the motor and it made no difference. The rails don't look bent or anything damaged.
Any suggestions will be appreciated.
Seagator
1985 K10 S/B Diesel
SEAGATOR5 is offline   Reply With Quote
Old 05-04-2009, 04:53 PM   #2
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Re: Need power window help
Where did the motor come from?
Did you lube the guide channels?
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 05-04-2009, 05:01 PM   #3
SEAGATOR5
AutoZone and sprayed rail with white lithium grease.
Old 05-05-2009, 05:31 PM   #4
chevyman8
chevyman8's Avatar
That's funny, I have the same problem only my window stops halfway and i have to pull it the rest of the way up.
chevyman8 is offline   Reply With Quote
Old 05-05-2009, 05:34 PM   #5
flamingbig10
6.0 powered square
flamingbig10's Avatar
I would also check your grounds and connections
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 05-05-2009, 05:45 PM   #6
JohnC
JohnC's Avatar
You may call Autozone. It's not unheard of to get a bad motor even though it's new. A lot of those are remanufactured.
JohnC is offline   Reply With Quote
Old 05-05-2009, 05:53 PM   #7
TwinTurbo
TwinTurbo's Avatar
Either check for voltage at the connector or get a spare battery and hook it straight to the motor. If the window flies up and down you ahve a bad connection and need to sort it out to get full 12~13V to the motor.
TwinTurbo is offline   Reply With Quote
Old 05-06-2009, 02:03 PM   #8
truckincurt
i would check how much voltage you are getting at the motor you might have a voltage dorp problem so your motor isint getting it required power to run at optimal speed
truckincurt is offline   Reply With Quote
Old 05-06-2009, 06:28 PM   #9
JMac11
JMac11's Avatar
120 AMP alternator will not fix it......
125.00 New motors/regulators
18.00 Junkyard window
30.00 New Switches
50.00 Window Felt kit
100.00 Alternator.
My Dad was a GM tech back in the day, says powdered graphite the new felts lightly. He said that GM had a "felt lube" powder years ago, but it cannot be found. If that doesn't work, rewiring with relays.
JMac11 is offline   Reply With Quote
