Old 05-04-2009, 01:04 PM   #1
flamingbig10
6.0 powered square
flamingbig10's Avatar
going to lift to up the rear today
I finally got tired of the rear sagging and not being able to haul and weight in my truck since only have 3 leafs and I'm going add two back
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 05-04-2009, 10:23 PM   #2
flamingbig10
6.0 powered square
Re: going to lift to up the rear today
well got the back lifted today took almost all day though I'll take some pics tomorrow. adding the two leafs lifted the back over 2 inches
Aaron
Old 05-04-2009, 10:59 PM   #3
flamingbig10
6.0 powered square
here is a teaser shot
Aaron
Old 05-05-2009, 12:12 AM   #4
heavychevy79
Cheyenne Super
heavychevy79's Avatar
Yeah that's better for sure, I can tell allready.
The friend I sold my 77 to wanted the rear lifted back up, so I switched the
drop shackles to my 78, and now I can't stand my truck being level, ack!
heavychevy79 is offline   Reply With Quote
Old 05-05-2009, 08:59 AM   #5
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Definitely looks better. It'll be better for your landscaping as well.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 05-05-2009, 09:15 AM   #6
JohnC
JohnC's Avatar
Looks good man, and I agree it will be more functional for you as well.
JohnC is offline   Reply With Quote
Old 05-05-2009, 02:00 PM   #7
flamingbig10
6.0 powered square
thanks guys it even rides a little better, but I think I'll stop landscaping out of my truck since the interior is a lot nicer than before
and then I added around a hundred pounds of junk in the bed
Aaron
Old 05-05-2009, 04:32 PM   #8
JohnC
JohnC's Avatar
I think it looks a lot better. However, I like the rake look better then the level. So my opinion is a little one sided.
Old 05-05-2009, 04:37 PM   #9
flamingbig10
6.0 powered square
thanks I'm going to try to lower it no more than inch in the rear, and I found out the passenger leafs are soft, and the driver side is stiff
Aaron
Old 05-05-2009, 10:22 PM   #10
flamingbig10
6.0 powered square
Tomorrow I might add some drop shackles and set them at lowest setting and see how it looks, also I'll have to replace the u bolts on driver side some how they got cross threaded
Aaron
Old 05-05-2009, 10:28 PM   #11
79Silv4x4
Workaholic
79Silv4x4's Avatar
The sloped driveway doesn't provide a good image/perspective of the actual stance. . .
1979 K-10 Silverado (work in progress)
1991 V1500 Subruban
1999 Suburban LT 4x4
2006 Suburban LTZ (daily driver)
79Silv4x4 is offline   Reply With Quote
Old 05-05-2009, 10:44 PM   #12
flamingbig10
6.0 powered square
I'll take some better pics Tomorrow if I get the rear suspension back together
Aaron
Old 05-05-2009, 11:02 PM   #13
cochino12
It followed me home?
cochino12's Avatar
Looks great, I like a little rake too though
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 05-05-2009, 11:17 PM   #14
flamingbig10
6.0 powered square
thanks, if I keep the rake I'm going to add 295/50, when it's time for new tires
Aaron
