05-04-2009, 03:18 PM | #1 |
axel interchange
will a 5 lug axel fit a 6 lug rear both12 bolt
Bob |
05-04-2009, 03:59 PM | #2 |
Re: axel interchange
I wouldliketo know as well I searched but couldnt find a difinitive answer.
05-04-2009, 05:59 PM | #3 |
Ive heard the 5 lug axle is just a little shorter than the 6 lug axles there fore the axles will not interchange, youd have to swap the whole rear end to convert to 5 lug
1967custom |
05-04-2009, 06:58 PM | #4 |
member #16
During the 1970 model year GM changed to the wider housing w/ longer axles. So if you have a 1970 housing chances are the five lug axles will fit.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
05-04-2009, 06:59 PM | #5 |
1971/72 5 lugs rears are a different width tha 70 and older. Just replace the whole rear end.
05-04-2009, 08:09 PM | #6 |
no, they are deffinatly different. the 5 lug axles are for sure, 100% positive shorter than the 6 lug axles. swapping out the whole rear end would be ok though.
1965 c/10 swb 1969 c/10 lwb |
05-04-2009, 09:19 PM | #7 |
I swapped 6 lug to 5 lug axles in my '68. The 5 lug axles are from '72, not sure what year 6 lug rearend was. Its not the original. When i swapped out the axles, i used the '72 5 lug axles and backing plates. It worked for me. It was going to be a little more work for me to swap rearends. MY '68 gmc is leaf and the '72 was coil.
05-05-2009, 05:39 AM | #8 |
I guess my question should have been , could you use a newer ring & pinion that had 6 lug axles and use my 5 lug axles in the 71 housing? or use the whole center section?
bob |
