speedometer delete
i don't use it or drive it enough or fast enough to get pulled over, and my cable leaks at the tranny. is there a speedo delete cap i can buy somewhere and screw on the tranny?
Re: speedometer delete
no fluid is in speedo cable so your leak is from the tranny where the sending unit is//
#3 | |
Active Member
![]() Join Date: Jul 2007
But, if it were me, I'd just take the plastic driven gear, count the teeth, go over to the Chevy dealer and get a replacement along with a housing "O" ring seal. Maybe get the whole housing asm and the gear. I think I paid less than $20 for the whole thing last year. Napa may sell them also. Last edited by 68gmsee; 05-04-2009 at 06:25 PM. |
Plug the cable in spread silicone around it then screw it back together it will stop leak.
Restoration Virgin!
Hey Matt,
I had the same problem...which tranny do you have....here's a thread from me...I have a TH400....http://67-72chevytrucks.com/vboard/s...d.php?t=333049 I'll also post up a thread for a TH350 (i think) for ya as well....http://67-72chevytrucks.com/vboard/s...d.php?t=331407
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present Last edited by gcburdic; 05-04-2009 at 10:27 PM. |
![]() Join Date: Oct 2006
If you really want it gone, remove the whole gear driven unit, and replace with a freeze plug. The 4x4s have a freeze pug in that hole from the factory because the spedo cable is driven off the transfer case on them.
freeze plug? what size do i ask for at the parts store? like for a ford 351 or chevy v6... or will they sell th350 freeze plugs? let me add i have a th350
Between Trucks...
Probaly just as cheap to fix it correctly.
Beat it to fit, Paint it to match... ![]() |
i'm looking to clean up the dash, just need a fuel gauge and i can hide that and my oil volts and water, but i'm not sure how i'm going to do it. its a custom truck, not a daily driver.
I guess if you never sell the truck, it would be O.K. , but if are ever in a situation down the road where you want to sell, or have to sell the truck, that will be a huge minus for the buyer. Just a thought.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD ![]() Click here to support the board Philippians 4: 6-7 |
Son of a gun
how will you know when to change the oil????
Bill BEATERS ARE NEATER |
