05-04-2009, 05:48 PM | #1 |
Alright Alright Alright
carb flooding problem
i just installed an iron intake on my cheyenne because i stripped a bolt in the aluminum one and need this thing on the road. yesterday, i put the right sized jets and needless back into the carb and when i got it all buttoned up, the carb overloaded and fuel started to come out of the accelorator pump. i took the carb off and took it apart again to make sure that everything was in check and there was no debris in the needle and seat area. with everything back in place, the truck idles and drives fine, but there is a little smoke in the exhaust. how can i lean this thing out? the jets are # 71 and the needles are #45. the only thing that is changed is the intake. the truck has always had this needle and seet combination. should i lower the float level?
1972 Cheyenne Chevrolet red and white 357ci, Vortec heads, GM Performance high rise intake, Comp 268H .454/.454 218/218 110 LSA Quadrajet carb, Flowtech headers, 2.25 40 series HEI, Curve kit, TH 350, 3.07 gears 275/60/15s on 15x8 rallies Last edited by crm318; 05-04-2009 at 05:50 PM. |
05-04-2009, 06:48 PM | #2 |
Re: carb flooding problem
what type of carb? Edelbrock or quadra jet, if its a Holley I'd say the floats. Prolly the same on the Edelbrocks also but not sure.
1968 chevy shortbed, Dark Shadow Gray 4 bolt 383 Stroker,Weiand Super Charger, disc brakes, 9 inch, 391 gear, 20" Eagle wheels, muncie 4 speed/ Hurst shifter, 4/7 drop, Hedman midlengths, 3 inch exhaust w/ 2 chamber flows. 1966 Mustang with 306 roller, c-4, 9 inch Detroit locker rear. 1965 Fastback Mustang w/347 stroker, top loader 4spd, 9 inch detroit locker. 1966 Mustang coup, 306 roller, c4, 9 inch. 65 Cobra, 427, T6oo, 9inch, of course. First gen Hayabusa, airbox mod and running 2 exhaust cams.. Zoom Zoom Zoom |
05-04-2009, 06:53 PM | #3 |
They used to have a lot of trouble with Q jet floats way back when. There was a series of them that would soak up gas.
I'd still be suspicious of dirt especially if you turned the car upside down at any time. Most likely you can helicoil the alunimum intake and have it be fine. |
05-04-2009, 07:32 PM | #4 |
did it have brass floats? Maybe a crack? if you took it apart. If not it sounds like the float stuck, or is out of adjustment.
05-04-2009, 08:08 PM | #5 |
Junior Member
Is it a Holley?
05-04-2009, 09:46 PM | #6 |
im sorry guys, i should have specified. its a quadrajet and it has the black plastic type float. when i took it apart, i sprayed every little orffice and pathway. i also took the seat out and cleaned that area very well too. there should not have been any debris in it the second time i put it back on. do you think that the float should be bent downward a little more?
1972 Cheyenne Chevrolet red and white 357ci, Vortec heads, GM Performance high rise intake, Comp 268H .454/.454 218/218 110 LSA Quadrajet carb, Flowtech headers, 2.25 40 series HEI, Curve kit, TH 350, 3.07 gears 275/60/15s on 15x8 rallies Last edited by crm318; 05-04-2009 at 09:47 PM. |
05-04-2009, 10:06 PM | #7 |
Eat My Rust
Possibly the float level got messed up, and it's taking in a little too much gas. IIRC, lowering the float level should help lean it out some.
