12-28-2002, 02:10 PM | #1 |
Odd marking on T-350 ?
This tranny/np205 supposedly was removed from a 72 Jimmy...can anyone id these markings
Thanks, Charlie
71 Hugger Orange Blazer..currently under off-frame resto to her original beauty. |
12-28-2002, 02:11 PM | #2 |
entire assembly
2nd pic
12-28-2002, 03:30 PM | #3 |
That almoust looks like an old Rockwell transfer case. I use to have one in my 68 and swapped it out for a 205.
68 4x4 402 big block |
12-28-2002, 03:41 PM | #4 |
its all about the +6 inches
You think that is odd...mine has an identity crisis...it says C4 on the bellhousing. (ford tranny designation for those of you NOT in the know)
12-29-2002, 11:58 AM | #5 |
PROJECT 7DEUCE
Thats funny cause i pulled my th350-205 combo outta my 72 blazer and it had a L cast in the same place on the tranny housing...
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
12-30-2002, 01:33 PM | #6 |
RPO codes (regular production option) were sometimes cast into the bellhousing. My TH350 book doesn't list "7J" though. It says 69-72 models had a code stamped into the 1-2 accumulator cover or the vertical surface of the oil pan. For example, mine is Y9H20D, which decodes to: Y=Toledo plant, 9=1969, H=June, 20=20th day, D=day shift. The book also says the Vehicle ID number (VIN) is sometimes stamped into the passenger side of the case just above the oil pan flange near the converter.
Mike 1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
