Old 05-04-2009, 09:11 PM   #1
syncrov69
syncrov69's Avatar
Question Picture of manual transmission crossmember and support
I like to convert my 1971 from th350 to manual 3 speed transmission. Do you have picture of crossmember and support(installed) that I need to make the conversion . Can I reuse my automatic crossmember to support the rear end of the manual transmission? Thank's, François
'71 Custom/10 Deluxe LWB
'71 Custom/30 Deluxe Dually
syncrov69 is offline   Reply With Quote
Old 05-04-2009, 10:03 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Picture of manual transmission crossmember and support
No need to convert the crossmember. You can reuse your existing auto trans crossmember and mount under the new standard transmission.
Old 05-04-2009, 10:05 PM   #3
syncrov69
syncrov69's Avatar
you don't have to add crossmember to support the rear of the engine or bell housing?
Old 05-04-2009, 10:36 PM   #4
Tx Firefighter
Not needed. As a matter of fact, starting in 73, GM went to the rear crossmember only and did away with the bellhousing unit on all trucks.
Old 05-05-2009, 05:28 AM   #5
syncrov69
syncrov69's Avatar
Thank's for the info firefighter!
Old 05-05-2009, 10:04 AM   #6
monte0185
monte0185's Avatar
Just out of curiosity is there an advantage to switching from the bellhousing crossmember to the auto crossmember? I know the auto crossmember bolts on the tailhousing of the tranny so it should cut down on torque to the carrier bearing. Just thought id pose the question.
A computer once beat me at chess, but it was no match for me at kick boxing.
Duct tape is like the force. It has a light side, a dark side, and it holds the world together.
monte0185 is offline   Reply With Quote
