"something witty here"
gen 3 in 55-57
Is the gen 3 motor, compatible with the 55-57. Has anyone here done it, and if so, do you have any info and advice?
57 chevy 4x4 70 swb fleetside 4x4 68 burb 2wd: 71 burb 2wd: 350 4spd 71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear 72 lwb fleetside Cheyenne 454/th400 1991 GMC V3500 CC 4x4 |
A320 Pilot/USAF Retired
Re: gen 3 in 55-57
I'd like to see some info on this too.
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
Re: gen 3 in 55-57
I know, I have a 5.3 and want to stick it in my 57, but cant find much info about people using the 5.3 in 55-57 chev gmcs.
Re: gen 3 in 55-57
I have written articles on doing these swaps on some sites and do them for a living. Ill be starting my swap into my 58 in a few weeks. Start to finish on the swap will be about 2 weeks and it will be my daily driver. Even though this site and I don't get along I may make a build thread if the site Nazis allow it.
Certified Car Nut
Re: gen 3 in 55-57
I was going to do this swap, I have anything to do it, but changed my mind (with me that's common.lol). Here is a link you can read to get an idea as to whats involved. http://www.classicperform.com/tech_a...ngine-Swap.htm
Re: gen 3 in 55-57
Z, I hope you can put your feelings aside and do us all a favor and let us follow along with your swap! Thanks!!
Dr. Frankenstein
Re: gen 3 in 55-57
i was thinking of swapping my 396 for a 6.0 and some hairdryers (have most of it laying around already) it seems to be catching on me more and more
I Wanna Go Fast!! |
#8 | |
Re: gen 3 in 55-57
What made you change your mind? Kim |
Certified Car Nut
Re: gen 3 in 55-57
Re: gen 3 in 55-57
got my truck today, set the mockup motor in it, flipped some manifolds forward and they fit so I think Im gonna turbo it for a fun daily driver...
teasers: ![]() ![]() ![]() ![]() ![]() |
Re: gen 3 in 55-57
Hey Z. Can you give us any details to kick off this swap? I can see it's a 58 GMC, but the front clip is from something else. I'm guessing camaro. Are the engine mounts the same as ones used for the stock chassis? Any issues with oil pan clearances? Is that a 5.3? Sorry for so many questions, but inquiring mind need to know.
58 Apache short fleetside ona 64 chassis: ![]() |
Dr. Frankenstein
Re: gen 3 in 55-57
Yes! this is gonna be Sweet, i was thinking this exact same idea for my 55'
I Wanna Go Fast!! |
#13 | |
Tripple Five Fanatic
Re: gen 3 in 55-57
#14 |
Certified Car Nut
Re: gen 3 in 55-57
The 5.3 oil pan does hang too low for me (I have a mustang 2 IFS). You can use the 5.7 oil pan, wingtray, and pickup tube. Its just that easy.
#15 |
Certified Car Nut
Re: gen 3 in 55-57
Or buy the expensive top mount bracket.
#16 |
Re: gen 3 in 55-57
The front stub on mine is a 75 Nova. The motor mount stands are up pretty high so the truck pan on mine is even with the crossmember, which is good cause I will have the truck sitting low someday. The truck is actually a 59 GMC, not a 58...like I said, I just got it yesterday. It's outside getting rained on now, which is super since some if it is bare metal.
#17 |
![]() Join Date: Nov 2008
Re: gen 3 in 55-57
Check my thread i'm doing a 5.3 in my 55 GMC.
Jean-Marc Lacasse 57 GMC 55 GMC 55 Belair 99 S10 http://67-72chevytrucks.com/vboard/s...d.php?t=316140 http://67-72chevytrucks.com/vboard/s...d.php?t=806011 |
#18 |
Re: gen 3 in 55-57
Another vote here on a how to thread for putting an ls in a task force. Im considering buying a wrecked silverado and retro fitting my 59 with all the drivetrain and wiring...
#19 |
Re: gen 3 in 55-57
Any updates??
#20 |
Re: gen 3 in 55-57
Today I'm going to look at a 5.3 for sale. The guy says it has 21,000 on it "i find it hard to believe" but he also says it runs. It's suppose to be a 2001 5.3, but, is the dished pistons in a 5.3 vs flat top pistons in te 4.8 a for sure way to tell the difference?
#21 |
Re: gen 3 in 55-57
Bump.. I have the 5.3 now, planning on how to make it work. I started making the motor mount adapters out of 1/2 plate (all I had). I have a 59 and I was thinking about fabbing my own fuel tank (aluminum or stainless) and am not sure what type of mechanics I'l need in the the tank. Im trying to be as tight with the budget as possible. Ive herd alot about Walbro inline pumps, cheapest route? What type of sending unit could I use? Fuel filters? lines? fittings? Junkyard parts are a plus in my book
#22 |
Re: gen 3 in 55-57
Hey Hotrodrookie,
Go back to the donor truck and carefully remove plastic fuel lines. I used the plastic lines from the Impala SS donor for my truck and it saved me lots of extra work, they hook up to the fuel rail and filter properly and when you buy your Walbro 255 fuel pump you can get the proper fitting there too. Mine came in 3 separate pieces and after using 2 of them I only had about 12" extra to secure at the tank (between the rails under the bed). |
#23 |
Re: gen 3 in 55-57
Ya, unfortunetly there is no donor car. Maybe i could check for some lines at the yard though.
Anyone have info on the corvette fuel filters? Do they make it so you just run a return line to the filter instead of going all the way back to the tank? |
#24 | |
Re: gen 3 in 55-57
http://www.ls1tech.com/forums/conver...ilter-fpr.html Connectors: 3/8" female connector DOR-800-121 www.midwayautosupply.com $7.36 5/16" female connector DOR-800-120 www.midwayautosupply.com $7.36 3/8" x 12" double ended male connector DOR-800-155 www.midwayautosupply.com $9.57 |
