Old 05-05-2009, 12:11 AM   #1
chev-obsession
chev-obsession's Avatar
disc brake rubber to hard line??
i am converting my truck (69) to disc brakes and i need to know where the bracket for the (72) that holds the steel brake line, when it turns into the rubber hose supposed to be welded at? if that made sense?
1965 c/10 swb
1969 c/10 lwb
chev-obsession is offline   Reply With Quote
Old 05-05-2009, 08:32 AM   #2
rlm316
rlm316's Avatar
Re: disc brake rubber to hard line??
The tabs are located on the front of the crossmember at the bottom. If you are using the lines from the '72, which are routed differently than the '69, follow the lines and mount the tabs at the end.
rlm316 is offline   Reply With Quote
Old 05-05-2009, 08:56 AM   #3
my67chevytruck
Under Construction
my67chevytruck's Avatar
If i recall correctly he only replaced the UCA, LCA's and drag links etc. the crossmember was not replaced because the engine was still in the truck. I will see if i can snap some pics shortly.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 05-05-2009, 09:08 AM   #4
my67chevytruck
Under Construction
here is a pic of the location, this is the drivers side....
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 05-07-2009, 08:50 PM   #5
chev-obsession
thats right
thanks for the pic thats exactly what i needed, do you know if i can cut my old one off and re-weld it in the front? If so, what would be the best way to do that?
1965 c/10 swb
1969 c/10 lwb
Old 05-08-2009, 07:59 AM   #6
rlm316
rlm316's Avatar
This is how I routed mine.
Old 05-08-2009, 01:03 PM   #7
my67chevytruck
Under Construction
Originally Posted by chev-obsession View Post
thats right
you could probably saw-zall or use a cutting wheel to get it off. Does you buddy still have the suburban xmember, maybe you could just cuti it off of that xmember
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 05-08-2009, 01:04 PM   #8
my67chevytruck
Under Construction
RLM316, that is a nice clean approach as well.....
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 05-08-2009, 09:31 PM   #9
chev-obsession
rlm316, thats a good idea! where did you get those long brake lines form? i htink im going to have to end up getting longer lines.
My67chevytruck- yes he does, i think i will go get it. by the way, can an allignment shop move the tires up and down? it seems like the tires ar cupped in a lot on the drivers side but no tso much on the passenger side....
but any way, thanks for the help so far! its greatly apperciated!
1965 c/10 swb
1969 c/10 lwb
Old 05-09-2009, 01:28 PM   #10
my67chevytruck
Under Construction
an alignment shop should be able to adjust the caster and camber and get you setup correctly. You should always have the alignment checked/set when doing something like you have done to the front end. Good luck with your project.
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 05-09-2009, 07:46 PM   #11
chev-obsession
ok, i planned on taking it down to an allignment shop first thing when it done.
Do you think that if i got the rubber lines for a 4x4, would they be longer than the swd ones? i think the 2wd ones that i got from right stuff are too short.
1965 c/10 swb
1969 c/10 lwb
Old 05-11-2009, 06:26 AM   #12
rlm316
rlm316's Avatar
The rubber lines are for the '91 donor brake system. The hard lines are for a 72 with some modification to go to that spot.
Old 05-11-2009, 07:05 PM   #13
chev-obsession
well thanks for the help. i got the brake lines all on finally!!!
1965 c/10 swb
1969 c/10 lwb
