Old 05-05-2009, 12:55 AM   #1
Wildstreak
"something witty here"
Wildstreak's Avatar
Transfer case???
Being a complete newb I don't know how to tell which transfer case is which, any advice? And could ya give me a hand and tell me what this is?
57 chevy 4x4
70 swb fleetside 4x4
68 burb 2wd:
71 burb 2wd: 350 4spd
71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear
72 lwb fleetside Cheyenne 454/th400
1991 GMC V3500 CC 4x4
Wildstreak is offline   Reply With Quote
Old 05-05-2009, 01:40 AM   #2
pulltilbroke
pulltilbroke's Avatar
Re: Transfer case???
That would be a new process 203
the big aluminum tailhousing and the shift linkage give it away
60 4x4,235,SM420,Rockwell T221,D44/HO33 sold 4/12
67 C-20,292,SM420,HO72
90 Dodge W250 Cummins,NV4500HD,205,D60/D80
93 Dodge W350 Dually Cummins, Getrag, 205,D60/D70
pulltilbroke is offline   Reply With Quote
Old 05-05-2009, 10:26 AM   #3
Wildstreak
Wildstreak's Avatar
Is it any good, and what is the recommended transfer case of 4weelers?
57 chevy 4x4
68 burb 2wd:
Old 05-05-2009, 12:04 PM   #4
Burt4x4
Burt4x4's Avatar
NP203 = chain drivin(not as strong & possiable full-time 4x4)
NP205 = gear drivin(strongest & part-time 4x4)
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 05-05-2009, 12:14 PM   #5
ghettoluxury
ghettoluxury's Avatar
It is what I run, it all depends on what you plan to use your 4x4 for. The NP203 has a gear driven range box with a chain driven 4x4 section and it is a very heavy cast iron unit with low gear of 1.96:1. The NP205 is completely gear driven with a cast iron case and will bolt up to a 2 wheel drive TH400 and it also has 1.96:1. The trail guys like to combo the front range box from the NP203 with the NP205 case to make a Doubler for a low gear of 4:1. The NP208 is a chain driven unit with a aluminum housing and it has a low range of 2.6:1 and this is the case i used untill I went to a TH400 since it is light weight an has a lower gear ratio.
ghettoluxury is offline   Reply With Quote
