05-05-2009, 09:53 AM | #1 |
S-10 frames ??
ok im having trouble finding a 95+ regcab lwb. I habe found quite a few 92's regcab lwb. my question is what is the difference? I asked a few S-10 guys and they said there is not really any diffrance. So that said what is the reason for people telling me 95+ regcab lwb ?
05-05-2009, 11:28 AM | #2 |
Re: S-10 frames ??
Not really sure why you are looking for a 95+... I'm in the process of doing my S10 swap right now and I just used a '91 (it was an extended cab so I had to cut 5" from it) but I would think any standard cab long box would work... only thing you are looking for is the correct wheelbase.
Cheers, Ted.
'51 Chevy Build - In the design stages Aut viam inveniam aut faciam - I will either find a way or make one. If you don't have time to do it right the first time, when will you... My new build - https://67-72chevytrucks.com/vboard/...70#post8958970 |
05-05-2009, 06:53 PM | #3 |
Re: S-10 frames ??
i'm using a 93 s10 reg cab short box. the older s10's are eaiser to convert the gas tank if you are running a carb steup thats about it. the newer s10 98 and up have disk brake rear that is why guys like them so much.
There is nothing you can't fix with a BFH or a FIRE WRENCH. 1997 chevy k1500 ext cab z71 (daily driver) sold 1996 chevy k1500 reg cab 4x4(daily driver)totaled 2008jeep patriot (wife's daily driver 2008 chevy 1500 ext cab 4x4 sold 2011 chevy 1500 crew cab ltz (daily driver) 1996 chevy 1500 reg cab 4x4 project sold 2006 pontiac grand prix gxp (daily work commuter) |
05-05-2009, 08:43 PM | #4 |
Re: S-10 frames ??
I used an 83 reg cab long bed. As far as I can tell, it doesn't really matter what year. It's all basically gonna be the same stuff to deal with. The newer ones just have more crap to take off if you have the the entire truck to tear apart. Other than that, once you get it down to the frame it's the basically the same.
Later Josh |
05-05-2009, 10:01 PM | #5 |
Re: S-10 frames ??
all s10 frames are the same.
the brakes and gas tank and i think motor mounts and such are different. |
05-05-2009, 10:23 PM | #6 |
Re: S-10 frames ??
well I thank everyone for the info im picking up a 92 std lwb this weekend to strip down.
anyone ever do a cummin's 6lb swap in a 52 yet ? |
05-05-2009, 11:44 PM | #7 |
Re: S-10 frames ??
someone was talking about it. like a 6bt or something
I think their really long and their effing heavy. |
05-06-2009, 12:04 AM | #8 |
Re: S-10 frames ??
05-06-2009, 12:59 AM | #9 |
Re: S-10 frames ??
Not sure if the frame can handle the weight.
Ted.
05-06-2009, 10:11 AM | #10 |
vintage car junkie
Re: S-10 frames ??
Not true. Same suspension and brakes all the way. The blazers had rear discs. Only diff should be the gas tank setup.
1950 chevy truck, s10 swap, bagged, v8, 18s My build: http://67-72chevytrucks.com/vboard/s...d.php?t=392761 |
05-06-2009, 10:43 AM | #11 |
Re: S-10 frames ??
+1
My build, 53 GMC / S10 swap http://67-72chevytrucks.com/vboard/s...d.php?t=305723 My build, 59 Chevy / 88 fullsize swap http://67-72chevytrucks.com/vboard/s...hlight=sgtusmc U.S. Marines - Certified Counselors to the 72 Virgins Dating Club. |
05-06-2009, 10:48 AM | #12 |
Re: S-10 frames ??
More info:
http://67-72chevytrucks.com/vboard/s...ghlight=diesel http://67-72chevytrucks.com/vboard/s...ghlight=diesel http://67-72chevytrucks.com/vboard/s...ghlight=diesel
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
