C-Notch Question
I will just give some background info. I am new to resto jobs. 2 yrs ago I bought a '67 C-10 SWB, it was 50% done. Engine and trany were done and the truck had been lowered. But the rest of the truck I got in pieces.
Since I bought it I had it painted and have slowly put it back together. I is finally finished and ready to drive. Since I have never insured it before I need an inspection done. Took it in and the inspector failed it on a number of things, however the most worisome to me is that he says the c-notch was not done properly. He said that the frame needs to be boxed around the c-notch which mine isnt. It was just cut out and a piece of c shaped steel was welded in. Unfortunately I don't have picutures right now. Do you think this would be strong enough or do I need to box in the c-notch. The garage that did the inspection is a resto shop and I want to make sure thay are not trying to make some money on me. Also the rear suspension was converted to leaf spring instead of the stock coils. |
Between Trucks...
Re: C-Notch Question
I've seen a lot of trucks done that way. Don't know what the requirements are in Canada though.
Beat it to fit, Paint it to match... ![]() |
Nothing to see here.....
![]() Join Date: Jun 2007
get a second opinion. sounds like b.s. to me...
Doug ![]() ![]() The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson Last edited by tcb-1; 05-05-2009 at 12:36 PM. |
Tot Roddin'
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
Check w/the shop to see if a bolt-in c-notch would 'pass'. The bolt-in style notches are 1/4" plate doubled against the sides & bottoms of the original frame & secured w/GRADE-8 hardware.
If they say yes, & you want to DIY, cut the old c-sections out & bolt in the new ones. If they still won't pass this style of notch, get a second opinion. If the opinions are consistent, have one of the 2 shops do the work or box it yourself (boxing it should be more than sufficent).
resident oilfield trash
They are trying to make money off of you. Take it some where else
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada ![]() |
Maybe they are, maybe they aren't. Regulations are different there vs. TX. A second opinion will help make an educated decision vs. assuming or guessing.
