![]() Join Date: Dec 2008
driveline questions
i want to put a 700r4 in my truck i am hoping to get 650 hp w nitrous. do i need lock up or non lock up. who make manual valvebodies for them? will i still have to have a tv cable since i will be running a manual valvebody? or should i just build th350 to handle it. also will ece 5 lug conversion axles, auburn locker and richmond 4.10 with c clips handle this much power? or will i need to get c clip eliminators and custom alloy axles? who makes alloy axles for 68 12 bolt in 5x5 pattern? any help would be appreciate.
Re: driveline questions
o and will be making 450-500hp on motor and 100-150 shot. no slicks mainly street use. harldly use nitrous if any.
Look into the Turbo 700 kit. It's from Premier or Prestige, or something like that.
At 542hp to the crank in my motor I went with a fully built th350, I have a 12bolt with stock axles 373 gears. I did not go with a manual body because I did not want the hastle of shifting as I mainly wanted a street vehicle with some hump..If I decide to start running slicks or what not then I will do mini tubs and have a ford nine inch four link set up.
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
hey big al are you running an
hey big al are u running an aftermarket posi? and im guessing ur still using c clips
anybody got any info on that kit i cant find it also does any body have any more info
How about this? http://www.700r4l60e.com/store/catal...1993-p-41.html
I'll try to find info on that other kit. |
#9 | |
Yes I have the c-clips, 373's and an eaton posi unit.....
do after maket posi units have openings for c clips?
Professional Grade
![]() Join Date: May 2009
Try this site, I have used them, good prices, solid tranny, can make it manual valve body or whatever you like. http://www.outlawtransmissions.com/SearchResults.asp
Heavyest you can build a 700r4 shipped to you with a converter and no core for $1375 seems allright to me.
61 GMC 9' Step Someday it will be a build http://67-72chevytrucks.com/vboard/s...=1#post3356828 67 C-30 Red Dale motorhome http://67-72chevytrucks.com/vboard/s...31#post3845531 71 GMC Street performer in the works ![]() Waiting for warm weather http://67-72chevytrucks.com/vboard/s...d.php?t=341946 1990 GMC Sierra GT-sold 1983 chevy 4x4-project on hold maybe sell 1969 Triuph GT 6- sold 1996 Ford I-6 5 Speed 4x4 2004 Dodge Intrepid- milage maker 1959 Ford Fairlaine, factory a/c 292Yblock- sold 1982 Honda XL500R Always lookin for other old trucks! |
