![]() Join Date: Jan 2007
Parts List Checklist - Camaro Rear Disc Brakes Using Glock's Brackets
Just getting my parts list together and wanted to confirm with anybody else out there who had done this - if I am on the right track...or if I have left something out - or if you have used something different/better that you could recommend. I will be placing my order this Friday and if you have any insight - let me/us know.
Thanks. 1. Glock’s Camaro Brake Brackets - $95 2. 93-97 Rear Loaded Calipers – www.RockAuto.com a. Right A-1 CARDONE Part # 18B4540 (with mounting bracket) - $118.89 ($45 core) b. Left A-1 CARDONE Part # 18B4541 (with mounting bracket) - $135.79 ($45 core) 3. Rear Rotors (94-96 Impala SS) – www.RockAuto.com a. RAYBESTOS Part # 56450R {Professional Grade} - $27.79 each - $55.58 4. 93-97 Camaro Rear Brake Lines – www.RockAuto.com a. (2) RAYBESTOS Part # BH380483 {Professional Grade} – (10.99 each) - $21.98 5. 93-97 Camaro Parking Brake Cable – www.RockAuto.com a. WAGNER Part # BC133076 - $21.89 6. Metric Brake Line Adapters – www.gatewayfasteners.com – Part #1442 - $.99 each – $1.98 7. Disc/Disc Proportioning Valve - PVKS4 - www.classicperform.com - more specifically - http://www.classicperform.com/Store/...ruck/PVKS2.htm - $75 8. Hardware Needed: a. (14) 3/8”-24x1-1/4” Grade 8 bolts – Tractor Supply Company – Bulk Bolts b. (14) 3/8”-24 Grade C nuts – Tractor Supply Company – Bulk Bolts c. (14) 3/8” hardened flat washers – Tractor Supply Company – Bulk Bolts d. (4) M12-1.75x25mm Grade 10.9 Bolts e. (8) M12 flat washers |
Never Ending Projects
Re: Parts List Checklist - Camaro Rear Disc Brakes Using Glock's Brackets
Outside of the brake lines, which I used steel braided lines, your list looks correct.
Oh, your loaded caliper may or may not have all the e-brake hardware attached. I hear that is hit and miss. It is good to have complete cores, to make sure you have all the parts. For what it's worth, what I research on this board and talked to ECE about, the stock drum/drum prop valve works fine. The allow equal flow to the front and rear, unlike a disc/drum setup. I am going to used my stock one and see how it works. Worst case, I add a replacement later.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
Thx for the response - It will be for a 72 so it already has disc brakes - so the MC might have to change as well...since it is a disc/drum MC.
My local TSC doesn't carry the metric or the 1.25" bolts - had to go to a local fastenal to get them... Anybody else have insight into this before I order this stuff up tomorrow? What MC are you all using on this conversion? |
For 70rs/ss: Items in green I have purchased already and will ship to you - red items can hopefully be purchased locally in AZ to save shipping costs.
![]() 1. Glock’s Camaro Brake Brackets - $95 2. 93-97 Rear Loaded Calipers – www.RockAuto.com a. Right A-1 CARDONE Part # 18B4540 (with mounting bracket) - $118.89 ($45 core) b. Left A-1 CARDONE Part # 18B4541 (with mounting bracket) - $135.79 ($45 core) 3. Rear Rotors (94-96 Impala SS) – www.RockAuto.com a. RAYBESTOS Part # 56450R {Professional Grade} - $27.79 each - $55.58 4. 93-97 Camaro Rear Brake Lines – www.RockAuto.com a. (2) RAYBESTOS Part # BH380483 {Professional Grade} – (10.99 each) - $21.98 5. 93-97 Camaro Parking Brake Cable – www.RockAuto.com a. WAGNER Part # BC133076 - $21.89 6. Metric Brake Line Adapters – www.gatewayfasteners.com – Part #1442 - $.99 each – $1.98 7. Disc/Disc Proportioning Valve - PVKS4 - www.classicperform.com - more specifically - http://www.classicperform.com/Store/...ruck/PVKS2.htm - $75 8. Hardware Needed: a. (14) 3/8”-24x1-1/4” Grade 8 bolts – Tractor Supply Company – Bulk Bolts b. (14) 3/8”-24 Grade C nuts – Tractor Supply Company – Bulk Bolts c. (14) 3/8” hardened flat washers – Tractor Supply Company – Bulk Bolts d. (4) M12-1.75x25mm Grade 10.9 Bolts e. (8) M12 flat washers |
I have a master cyl booster combo from a 74 Impala with disk/drum combo, can I use this setup on my new front disk with camaro rear disk brakes? Also it seems that the impala ss rotors are the 5x5 pattern, these are the same size rotors as the camaro uses I'm assuming?
My rear disk brakes are from a 85 camaro rear disk.
