LMC dual exhaust kits, how is the quality?
My truck desperately needs a complete exhaust, the front pipe is rust perforated (original pipe), and it only has one muffler and tailpipe.
I like the price of the LMC flowmaster kits for 249, but is it a good kit? will I have to do a lot of massaging to get it to look right? I'd ideally go for the Magnaflow kit, but I am trying to be frugal this year and am not ready to drop 550 on exhaust if I don't have to. Thanks for any input on the LMC dual kit.
2004 VW R32 450 HP money pit (faster than a Viper in the 1320 ![]() 2001.5 VW Passat beater 1972 Custom Deluxe Highlander 69k miles and counting, all original, even the paint ![]() |
Re: LMC dual exhaust kits, how is the quality?
don't know if this helps or not but i bought one of their single exhaust kits and was really pleased with the fit. i was trying to be frugal to and just couldn't pass up the price.
425hp409
![]() Join Date: Oct 2008
I bought one of their dual exhaust systems for my 68 and had to do alot of work to make it fit. I was going to install it at home, but after several hours of frustration, I trailered into my shop where I have a pipe bender and had one of my mechanics install it. Once it is on, it sounds real good though.
Charles |
I have their dual set up for my 4x4 and didn't have any problems at all. I love it. I would buy it again if I needed to.
Actually it's made by heartthrob.
1970 K20, 350--- SOLD 05 silverado extended cab short box- duramax Jeep wrangler unlimited Last edited by Ace in the hole; 05-05-2009 at 07:35 PM. |
i've done a couple of the lmc dual exhaust kits // once you figure out what goes where it goes together nicely// it helps to have the frame on jackstands and the rear hang down // piece it together loose and jack everything up into proper position before tightening anything
Wondering if the lmc dual exhaust kit would fit around the factory spare tire rack and tire? I had my dual exhaust done at an exhaust shop before I found the tire holder set up. Now it won't work. ED67C20
![]() Join Date: Nov 2004
I have a blazer tank where the spare tire would go, so yes, it would fit fine.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
I have the same kit LMC sells on my 4x4. Check out heartthrob.com they offer free shipping and if you get the kit without mufflers you are looking at $184 to your door. The hangers are a little cheesy but the pipes fit very well and will work with no problem around the spare tire. Mine installed in less than 1.25 hours but no bed or cab in place and that is welding in place.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
thanks for all the replies, I just bought a 14 ft Alumicraft so I need a sweet sounding truck to pull it with
![]() For the money, i am going to get the kit, thanks again
...just another truck junkie..
![]() Join Date: May 2009
You guys that have these exhaust kits installed, are you using the stock manifolds? I'm looking at them as well and want to make sure they work fine with the original exhaust manifolds.
Mike "Bear" Shea |
yep
1970 K20, 350--- SOLD 05 silverado extended cab short box- duramax Jeep wrangler unlimited |
It works with the stock center dump ramhorns.
If I had to do it all over again, I would have rather paid a shop a little more to build me an exhaust, but this one is "cheap" and works just fine. It's been on my truck since 2002.
#13 |
With the money you're saving through hearththrob.com, go through Summit and get a set of their $70 headers. They're basically Hedmann without the name. I've had a set for 5 years and they're still going strong.
#14 |
That would be a reasonable way to go if a person wanted headers. Not this boy, though. I am content with the rams horn manifolds.
Mike "Bear" Shea |
#15 |
I just got off the phone with my local exhaust shop, and for $400 complete, installed, I can get a complete dual exhaust system 2.5" pipes and Flowmaster 40's
I think I am going to go that route.
#16 |
I was gonna suggest to call around to the different muffler shops. Sometimes you can get a good deal and not have to put up with putting the system together yourself.
-Scott- |
#17 |
gintaras,
if you can get it built for $400, DO IT! the LMC kit isn't bad but the best price i was quoted was $600 so i did the LMC. matt
1970 C20 now a K30 ![]() 1986 3+3 Dually |
#18 |
Mine setup uses the stock manifolds and had no problems with bolting and going- only area that was even a little difficult was the t/c side and it was not hard. If you are looking for a stock type replacement system this set is a good set. 2.25 diameter pipe and you choose what mufflers you want if you just get the pipe kit so you come in @ right at $300 for flowmasters.
#19 |
Well, i dropped it off at the shop this morning, going to get full 2 1/4 duals with Flowmaster 40's
My truck only came with a single side exit, and I don't have an OEM bracket on the pass side like I do on the driver side, so I hope they do a good job and match the OEM mount somehow. I sure do hope these Flowmasters aren't too loud, maybe I should have got the Turbo muffles instead, when I asked how loud it would be with the FM 40's he said "extremely loud", then he said not as loud as cherry bombs, but louder than turbo's.. so I think that will work for me. We will see.. the last thing I wan is an obnoxiously loud slow truck ![]()
#20 |
OK.. FM 40 series may be to oloud so I chickened out.. The shop recommended something in between, louder than a "turbo" muffler, but quieter than a 40.. it is a 2 chamber, called an accelerator? or excellerator? Anyone hear of that before?
#21 |
Go with the 40's with a H-pipe it's not that loud.
#22 |
make sure they are going to use aluminized pipe.
#23 |
what kit number from Heart Throb is for our trucks?
#24 |
I just picked her up and I think it sounds great.. I will post pics and a vide later..
has anyone heard a a flowmaster vx series? THat is what I was told was installed
#25 |
well, here it is.. I fried my water pump at the end of the movie
