05-05-2009, 05:21 PM | #1 |
Why does it taste purple?
I have searched and cannot find..60's style truck/s-10 frame
Can anyone help me find the threads about swapping an s-10 frame under our trucks. I know it has been done before and im just tinkering with the idea. Thanks guys
Hello, my name is John and I'm a truckaholic |
05-05-2009, 06:20 PM | #2 |
Re: I have searched and cannot find..60's style truck/s-10 frame
I 'm not sure why you would want to.....
I have seen a couple on the web that used different frames(don't remember any on here), it is usually the older 47-54(?)'s that use the s-10 frames. they are quite a bit narrower than the 60-66's
CHEVY ONLY Last edited by joe231; 05-05-2009 at 06:21 PM. |
05-05-2009, 06:43 PM | #3 |
Not a good swap....
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi 1961 Impala SS 348/350 4-speed 3:70 Posi 1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed 1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear 1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc 1949 Transitier 3-wheel forklift Crosley 4-Banger 98' FXD 2002 2500HD |
05-05-2009, 06:54 PM | #4 |
1961 crewcab
there is not a good reason to use an s10 frame on our trucks, do some research on the board here, and use the 73-87 c10 parts on your frame.
I used to think that a camaro subframe was the way to go to lower and modernize a 60-66, (it is for a 55-59) then I found this board, and discovered how easy it is to utilize a 73-87 suspension, and all the aftermarket components that are made for them. Last edited by jonzcustomshop; 05-05-2009 at 06:55 PM. |
05-05-2009, 11:32 PM | #5 |
60-66 Nut
Putting one of these trucks on an S10 frame makes no sense at all. There are more than enough aftermarket parts, and OEM parts available to do anything you want to do with the original frame.
With that said.....why are you wanting to use the S10 frame?
