05-05-2009, 06:46 PM | #1 |
C4 corvette IRS in a '56
Looking for some info from those that know.
When setting up the center different, do I adjust it for pinion angle like pinion 3 degrees up? or does it go level? same thing with the motor...do I tilt it 3 degrees back as usual or set it in level? Then about the rear end.... Im assuming ride height is with the LCA's parallel to the ground? correct? I plan on using the stock spacing between the front bushings in the "trailing arms", but do I set the lower one level at ride height? or the upper? or split the difference? and a general q... how far down from height is it safe to go so I can calculate where I need to place the rear end to get the correct drop/ride height stance? and just for the hell of it...how safe is it to go higher than ride height? This isn't my first rodeo on a full frame but it is my first time with IRS and I couldnt find a decent book that had what I was looking for. I know porterbuilt deff. knows these answers, but any help is appreciated, thanks guys. |
05-07-2009, 08:23 AM | #2 |
Happy to be here
Re: C4 corvette IRS in a '56
Anyone?
05-07-2009, 09:56 AM | #3 |
I have never installed a C4 IRS so someone else might chime in with some more help but from my knowledge yes the rear pinion angle will need to +3 degrees give or take just like a standard solid rear axle application. It uses a driveshaft so it should follow the same principles. Regarding where to located the IRS in a vertical plane I would like to assume that the center of the half shalft would be the same height as the center of the wheel. For example. My rear tires are 275/30/20 which gives me a 26.5" tire. Take the center of that at 13.25" and that is the height of the center of the half shafts. I would also imagine that the 4 link style rear linkage that holds the spindles would have the similar qualities to a standard 4 link so like if they are at an incline you would get more antisquat % that kind of thing.
Now I want to repeat this. My answeres are based souly on common sence. I don't not know if my answeres are correct but I would hope i am pretty close to the correct answere. Just thought if i though some of this out there someone else might chime in and clearify it better. Hope i helped! Josh
(Project truck) 1970 C10 under complete transformation My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871 Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold |
05-07-2009, 10:03 AM | #4 |
Nathan from Porterbuilt gave me a call yesterday and helped me figure out all the specifics.
Im going to leave this thread pretty much unanswered until I can get a build thread going so I have pictures with my explanations. Josh your pretty close to what needs to happen. I too assumed you treat it much like a standard rear end and thats basically correct. thanks guys and especially Nathan from PB -Dustin |
