Old 05-06-2009, 12:34 AM   #1
jameskennedy
New member needs a little advice
Got my hands on a 75 Chevy 4X4 and want to put a 292 that I had in a van into the pickup, it had a 350 in it that I pulled already but the Im not sure what mount to use. The van frame mounts dont bolt up to the frame of the pickup, so for any ideas as to what passenger mount I should get and maybe where.
jameskennedy is offline   Reply With Quote
Old 05-06-2009, 12:48 AM   #2
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: New member needs a little advice
welcome to the site
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 05-06-2009, 12:53 AM   #3
jameskennedy
wondering if I could relocate my passenger side bracket forward a couple of inches to fit the 292 in?
Old 05-06-2009, 12:59 AM   #4
flamingbig10
6.0 powered square
I think the brackets for the 350 should work with the 292, not sure but I know the motor mounts are the same
Aaron
Old 05-06-2009, 01:53 AM   #5
jameskennedy
Mounts look like they'd work if the frame bracket on passenger side was moved forward 2 inches.
Old 05-06-2009, 01:56 AM   #6
jameskennedy
I figured someone on here musta put a 292 in a 75 4X4 and would know the procedure, but it really looks like a simle mod to the frame bracket would do the trick.
