Now the others dig........
![]() Join Date: May 2002
How do I connect a flip or pull switch for the use of the back up lamps?????
------------------ IN A TUX WITH A 68 BOWTIE. *SELLING FOR PARTS* "P.O.S" Stepside 68, Primed from Fl., rusted out a bit, but *SELLING FOR PARTS* Interested? E-mail me!! "Rusty" Stepside 68 Brown/Black (not by choice, soon to be charcoal grey) This is my baby, just put in wood bed. Overhauled 307. Just needs the brakes to be redone then its ready to run. Oh yeah, My girlfreind's got a 63 named "Blue Boy"
68 Chevy C10 Stepside Black Primer 78 GMC Longbed White 09 Chevy Silverado Shortbed Granite Blue LOOKING FOR A 67 4 DOOR IMPALA!!! ![]() MEMBER OF THE DRUM BRAKE CLUB Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX Certified Music Educator I hope Mom is up there watching and being my Guardian Angel "I've got a fever.....and the only prescription.....IS MORE COW BELL" -The Legendary: Bruce Dickenson "F#$@ 'em up!!!!!!" -The Legendary: Rogelio Escobar ![]() TRUCKY LINKS http://67-72chevytrucks.com/vboard/s...d.php?t=457750 http://67-72chevytrucks.com/vboard/s...d.php?t=461184 http://67-72chevytrucks.com/vboard/s...d.php?t=472848 http://67-72chevytrucks.com/vboard/s...d.php?t=417541 http://67-72chevytrucks.com/vboard/s...d.php?t=477788 |
there wil be two wires that plug onto the existing switch at the end of the top side of the column under dash, plug a male spade terminal into the female terminals in the plastic plug and run them to a switch. do not cut and splice....
------------------ Randy- Lincoln, IL randy@ccaonline.com 2177353230 *many GM parts bought, traded, or sold -am parting out: '81 Cutlass Supreme and 84 SE Firebird T5 3.73 current fleet: -71 C-10 350/CH465/3.07- assembling currently -90 Cavalier/2.2/sky blue, driver #2 -84 Z28 5.0L/700R4/3.73 daily driver #1 -'90 Corsica 3.1L and '82 purple Trans Am- storing *Paint is overrated* © RSS Enterprises 2000 [This message has been edited by Fast68Chevy (edited May 16, 2002).] |
Randy, what if it's a 4 speed? mine have not worked since I bought the truck 6 years ago. What do I look for?
Bill - Tucson ------------------ 56 Studebaker 2 dr Wagon 66 Chevelle 2 dr 4 speed 71 C30 Longhorn 86 Monte Carlo SS 96 Tahoe
Bill - Tucson, AZ 47 Chevrolet 2 dr sedan 56 Chevrolet 210 2 dr sedan 66 Chevrolet Malibu 2 dr 4 speed 71 Chevrolet C30 Longhorn 86 Chevrolet Monte Carlo SS (Sold) 01 Chevrolet Tahoe IM - BUSTERWIVE@aol.com |
Trace the wires back from the tranny, the lamps have to connect to the tranny somewhere.
------------------ 1968 SWB Stepside, pwr disc brake and tilt pwr steering, 5 spd tranny, HEI,Accel coil,K&N filter,3 bolt seatbelts, original i6 and wood bed, seat from an 89 Chevy, front and rear sway bars, moved gas tank to under the bed, headman hedders, new chrome bumpers,one wire alternator,WORK IN PROGRESS,Daily driver, 20 MPG, Freeland MI
1968 SWB Stepside, 250,pwr disc brake and tilt pwr steering, 5 spd tranny, HEI,Accel coil,K&N filter,Seat from a later truck with built in seatbelts, front and rear sway bars, moved gas tank to under the bed, headman hedders, new chrome bumpers,one wire alternator,Weber k550cub carburator...WORK IN PROGRESS, Freeland MI , Just bought a 72 Jimmy!!!!!!!!!!! |
Randy,
So there will be two male terminals going into two female terminals, Right? I.E..... -------O <-----------B F. PLUG M. PARTS SWITCH -------O <-----------A Then Back to the switch terminals, one the battery terminal and the other to the "apparatus" terminal? I hope my diagram came out O.K. ------------------ IN A TUX WITH A 68 BOWTIE. *SELLING FOR PARTS* "P.O.S" Stepside 68, Primed from Fl., rusted out a bit, but *SELLING FOR PARTS* Interested? E-mail me!! "Rusty" Stepside 68 Brown/Black (not by choice, soon to be charcoal grey) This is my baby, just put in wood bed. Overhauled 307. Just needs the brakes to be redone then its ready to run. Oh yeah, My girlfreind's got a 63 named "Blue Boy"
Old member
If you have a four speed and no back up lights, I would think who ever put the four speed in it didn't care about the back ups and never hooked them up. Depending on the transmission it should have a electric connection somewhere on the trans., that would have a hot wire coming from the fuse block then out of the connection to the lights, when you put it in reverse it makes contact and you have lights. Hope this helps.
------------------ Andy 71's Are for ever!!! or 67,68,69,70,72 71,factory tach,tilt for straight drive,gauges,ac,speed warning,clock,305 HO TPI with 700-R4, lowered 2" & 3" ,and 17" Chrome Stealth wheels, Pioneer reciever,100 watt amp, 6 disc changer, 2-10" subs (behind seat) 2-6x9 in doors, 2-3ways mounted under seat, and 2 tweaters on door panels www.geocities.com/chevy71tpi/main.html www.picturetrail.com/Andy4639
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
![]() Join Date: Sep 2001
Randy's talking about switches for automatics. That's IF you have an auto tranny (I don't know what you have). If you have auto then it's easy.
If not then you'll have to trace the back-up lamp circuit from the tail-lights to the firewall and then down to the transmission where there should be a switch... Either way you'll have to tap into the power and neutral sides of the circuit, and run a new power and new neutral to a switch on the dash or something. Is there a reason you don't want the stock setup to work? You just want manual backup lights? ------------------ '69 3/4 ton C20 2wd w/ 350ci/400THM and a wood bed! '69 3/4 ton Custom 20 2wd w/ ORIGINAL 350ci/4sp Manual and a wood bed (parts beast). Seattle, WA. *See pics of my trucks and project at www.webshots.com!
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
new69owner,
well, it is an automatic transmission, but the column is a 3-speed column that I'm rigging to work as auto. The only reason I'm adding a manual switch is because I'm not sure that the shifting will agree with the placement of the column switch. Sorry I didn't mention that it was a 3-speed column. Since we all know now, what would I have to do then, to add the manual switch. ------------------ IN A TUX WITH A 68 BOWTIE. *SELLING FOR PARTS* "P.O.S" Stepside 68, Primed from Fl., rusted out a bit, but *SELLING FOR PARTS* Interested? E-mail me!! "Rusty" Stepside 68 Brown/Black (not by choice, soon to be charcoal grey) This is my baby, just put in wood bed. Overhauled 307. Just needs the brakes to be redone then its ready to run. Oh yeah, My girlfreind's got a 63 named "Blue Boy"
