Old 05-06-2009, 03:35 PM   #1
number44will
Need some Help w/a carb
I just bought a 600cfm 1405 edelbrock for my 73 off ebay. I'm not sure if im missing some parts or whats going on cause there are two cables coming out of the fire wall (sry, 1st project not sure what they are called) the one on top is connected to the carb fine but the one one bottom (i think its the accelerator cable) has nothing to connect to and is not holding tension when i tried to ghetto rig it. Are there any pictorals on how to do this online? Edelbrock's manual sucks and doesnt help much. thnks
number44will is offline   Reply With Quote
Old 05-06-2009, 06:29 PM   #2
tgh117
Crazy
tgh117's Avatar
Re: Need some Help w/a carb
Is it possible that the second cable could be a manual choke? What carb did you take off the truck previously before you replace with the edelbrock? Too my knowledge the only cable coming from the firewall to the carb is the throttle that connects to the pedal. Depending on if you bought a 1405 with an electric choke, you may not need the second cable.
77 SB Stepside in a bunch of pieces scattered around the garage.
tgh117 is offline   Reply With Quote
Old 05-07-2009, 01:06 PM   #3
number44will
Question Re: Need some Help w/a carb
The bottom cable that goes to
http://i91.photobucket.com/albums/k2...3/IMG00515.jpg
the top cable that goes to
http://i91.photobucket.com/albums/k2...3/IMG00516.jpg
Old 05-07-2009, 01:54 PM   #4
OrangeAnimal
OrangeAnimal's Avatar
That is the throttle valve cable for the trans. You can buy a stud kit to to hook it up to the lower hole on the throttle lever. I you leave it unhooked the transmission will not shift right. I think the little linkage kit is about 15 bux. You can get one from Advance Auto Parts.
82 Chevy SWB "OrangeAnimal" Lot of Goodies! Sold
93 GMC 1500 "Angry Red" 383 TBI Powered Fun! 300hp/410ft.lbs.
09 Yaris wife's daily.
OrangeAnimal is offline   Reply With Quote
