auto steering column in a 1960
I've got a 1960 chevy truck and it has a newer (1978) tilt column that is garbage. I found a stock 66 auto truck column and want to install it. However what do I do about the plug ins for the turn signals? Also this 66 coulmn is for the t400.
Re: auto steering column in a 1960
was your original wiring butchered?
if so you can buy a new harness
yes the wiring is all messed up. I'm just wondering what wiring harness would I need? the 66 cloumn has two harness plugs (kinda half round) and the stock 60 has the turn signal switch is bolt to the lower portion of the column and is triangle like and utilizes a cable of some sort?
