Old 05-06-2009, 08:59 PM   #1
1-2many
1-2many's Avatar
Love Posi
Hi guys,
Does anyone know what kind of unit this is? I used to have it my Chevelle wagon. I put it in the 10 bolt rear with 3.08 gears but wasn't original to the car. A freebie that worked! I want to donate it to my friend's '67 C-10 project now that wagon is gone, but don't want to give him a piece of junk. You know, keep the positive Karma flowing.If it needs to be, can it be rebuilt, are parts still available? Would it be better to just get an aftermarket posi?
Free beer is good beer.
1-2many is offline   Reply With Quote
Old 05-06-2009, 09:49 PM   #2
jbristo67
resident oilfield trash
jbristo67's Avatar
Re: Love Posi
Yeah dont give your friend that piece of junk. Send it to Jerod Bristo 5204 90th Lubbock TX 79424 instead
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
Old 05-07-2009, 12:35 AM   #3
sierra4x4
sierra4x4's Avatar
Re: Love Posi
If that posi was in a chevelle than it won't fit in a truck. Chevelles had 4 types of diffs
64-72 had 8.2 10 bolts in 350 2bbl and smaller engines
64-72 had 8.875 12 bolts in 350 4bbl and bigger engines
73-77 all had 8.5 10 bolts
78-87 had 7.5 10 bolts
Trucks use 12 bolts from around 63 up until 81. In 82 trucks switched to the 8.5 10 bolt (same internals as the 73-77 chevelle). Also the car and truck 12 bolts are not the same.
sierra4x4 is offline   Reply With Quote
Old 05-07-2009, 01:06 AM   #4
Willys47
Willys47's Avatar
Re: Love Posi
car and truck 12 bolts are not the same. What are the differances? My diff is open and would like to get a posi for it, so what should I be looking for?
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!!
Willys47 is offline   Reply With Quote
Old 05-07-2009, 01:34 AM   #5
sierra4x4
sierra4x4's Avatar
Re: Love Posi
I believe that the width of the carrier is different and the pinion has a smaller diameter on the truck 12 bolt. When shopping for a posi remember that around 73 gm trucks switched to the gov-loc type(the explosive one) of limited slip. 72 and older used the eaton clutch style(the good one) limited slip.
Old 05-07-2009, 02:54 AM   #6
caja_larga
Re: Love Posi
while we are on the subject of posi's.
Ihave a posi in my truck and when I make a slow turn like in a drive tru or a slow left turn, It pops. Loud. What is the deal my dad says its normal. I hate it. whats the deal?
caja_larga is offline   Reply With Quote
Old 05-07-2009, 03:16 AM   #7
jbristo67
jbristo67's Avatar
Re: Love Posi
Its normal. They all do it.
2011 Nissan Armada
Old 05-07-2009, 10:10 AM   #8
nightmare
nightmare's Avatar
Re: Love Posi
that is normal, but when was the last time you changed the fluid? my truck did the same thing, but once i changed the fluid, most of the popping and noise went away.
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 05-07-2009, 10:11 AM   #9
72BLKCHEYENNE
72BLKCHEYENNE's Avatar
Re: Love Posi
Mine pops, I keep thinking something is broken and here goes another million dollars to fix it..... the rear didn't pop when it was in my 72 but after switching it to the 68 with a new axel and 20 inch rims and tires it just doesn't seem right...... but everyone say's it's normal, so I guess it's normal.
72BLKCHEYENNE is offline   Reply With Quote
Old 05-07-2009, 12:05 PM   #10
monte0185
monte0185's Avatar
Re: Love Posi
Its not normal!! It shouldnt pop!!! What you need to do is change the fluid unless its been recently changed and add a bottle of Posi fluid. It goes in with your gear oil and prevents the popping and makes it work correctly. I dont remember the exact name for it but its at every major parts store.
A computer once beat me at chess, but it was no match for me at kick boxing.
Duct tape is like the force. It has a light side, a dark side, and it holds the world together.
monte0185 is offline   Reply With Quote
Old 05-07-2009, 12:28 PM   #11
my67chevytruck
Under Construction
my67chevytruck's Avatar
Re: Love Posi
It's a limited slip/positraction additive oil. It smells aweful..... and no it should not pop when you turn. most likely your oil (80w90)needs to be changed, always add the additive when changing the oil. If its popping the friction plates are not releasing as they should when you corner. I bought my last bottle from NAPA....
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 05-07-2009, 01:51 PM   #12
monte0185
monte0185's Avatar
Re: Love Posi
Thats it. I couldnt think of the name of it and your correct it smells awefull!!!
Old 05-07-2009, 02:08 PM   #13
07SSSC
07SSSC's Avatar
Re: Love Posi
Bingo, mine always clicked around corners, changed the fluid and added some GM Limited Slip Axle Additive (#1052358) and no more clicky. I'm sure any brand works but I happen to work at a dealership, employee discount ftw.
'69 Chevy C/10-under reconstruction -- '68 C20 Camper 50th Anniversary-runs, but sorely needs a resto --
'07 Cobalt SS/SC-very fun DD -- '93 Chevy K2500-LQ4/4L80E swap --
'84 Trans Am-awaiting (LS) drivetrain -- '00 Trans Am-road tripper -- '06 Z06-577 WHP beast
07SSSC is offline   Reply With Quote
Old 05-07-2009, 04:27 PM   #14
1-2many
1-2many's Avatar
Re: Love Posi
An old mechanic friend of mine called it "fish oil", and it was from GM. I think fish oil smells better then the additive, but the GM stuff works really good.
The rear I had the posi in was an 8.2, 10 bolt. I yhink it's a 2 serries carrier. Does anyone have any other info about this old thing?
Old 05-07-2009, 05:51 PM   #15
07SSSC
07SSSC's Avatar
Re: Love Posi
Cuz it used to be made outta whale oil years ago or so I was told by another old tech. No idea what's in it now.
Old 05-07-2009, 06:37 PM   #16
1-2many
1-2many's Avatar
Re: Love Posi
That was in the '70's.
1870's?
Used to use that stuff in Saragossa.
Or was it Sarasota?
It came in a bottle...
Maybe it was a tall bottle.
Or was it a can?
