Old 05-06-2009, 09:55 PM   #1
DWright
Shlong Bed Club
DWright's Avatar
New Crossmember
i've noticed that a few guys on here have swapped their front cross-members with one from a newer ('70s) model truck. other than brakes and better spindles, what other advantages are there?
DWright is offline   Reply With Quote
Old 05-06-2009, 10:06 PM   #2
joe231
joe231's Avatar
Re: New Crossmember
cheaper and more plentiful parts on the '73-up stuff
CHEVY ONLY
Old 05-06-2009, 10:26 PM   #3
DWright
Shlong Bed Club
DWright's Avatar
Re: New Crossmember
i think i might have to do some looking around for a donor now
Old 05-06-2009, 10:32 PM   #4
joe231
joe231's Avatar
Re: New Crossmember
oh and rubber A-frame bushings, and front sway bars, and.......
CHEVY ONLY
Old 05-06-2009, 10:50 PM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: New Crossmember
For me, the rubber control arm bushings made it more sensible. Replacing the old type screw in metal bushings is very expensive.
I got all of my polyurethane bushings for 60 dollars from Summit.
Old 05-06-2009, 10:55 PM   #6
protrash64
Resistance is Futile
protrash64's Avatar
Re: New Crossmember
I re-did my front end with the old type screw-in bushings and I dont even know why....they look just about indestructible!! There was nothing really wrong with the old ones, either.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 05-06-2009, 11:25 PM   #7
DWright
Shlong Bed Club
DWright's Avatar
Re: New Crossmember
and the cross member just bolts in?
Old 05-06-2009, 11:56 PM   #8
Captainfab
60-66 Nut
Re: New Crossmember
Pretty much. You will have to drill one hole each side and elongate one hole each side. When it comes to the power steering box and the power brakes, that's a little more involved....nothing overwhelming though. It is all very much worth it in the end.
Old 05-07-2009, 07:00 AM   #9
DWright
Shlong Bed Club
DWright's Avatar
Re: New Crossmember
invovled is no big deal; i once crammed a 350 into a chevette.
Old 05-07-2009, 08:38 PM   #10
DWright
Shlong Bed Club
DWright's Avatar
Re: New Crossmember
just spoke to a guy i know that usually has tons of chevy trucks and parts and he said he has an early 80s 3/4 ton frame sittin around. he said its 2wd with 6-lug wheels. correct me if im wrong, but doesnt the 3/4 & 1 ton truck have 8-lug wheels? if it is 6-lug, will a 3/4 ton crossmember work under my '66 1/2 ton without putting it a mile in the air?
Old 05-07-2009, 10:57 PM   #11
Captainfab
60-66 Nut
Re: New Crossmember
If it is an early to mid 80's C20, then yes it will have 8 lugs. Starting is '88 there was a light duty (7200GVW) C20 that had 6 lugs. But those are a totally different frame. You could use a "73-'87 C20 crossmember but you would need to change the spindles if you didn't want 8 lugs. If you want to stay 6 lug, there is a way of doing that with combining factory parts from the above mentioned light duty C20's. Here is the link to the writeup
http://www.67-72chevytrucks.com/vboa...ad.php?t=35042
Old 05-07-2009, 11:56 PM   #12
DWright
Shlong Bed Club
DWright's Avatar
Re: New Crossmember
Sounds to be more trouble than its worth, i guess i'll just keep looking for a better donor. thanks for the info.
Old 05-08-2009, 12:17 AM   #13
SCOTI
SCOTI's Avatar
Re: New Crossmember
You can have all the benefits of the later model suspension w/the original crossmember. The newer a-arms will swap right over (as will the rest).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-08-2009, 06:56 AM   #14
DWright
Shlong Bed Club
DWright's Avatar
Re: New Crossmember
i know, i just liked the idea of a complete bolt in package.
Old 05-08-2009, 07:43 AM   #15
joe231
joe231's Avatar
Re: New Crossmember
Hey John, will the c-10 spindle mount to the c-20 lower ball joint?
CHEVY ONLY
Old 05-08-2009, 08:36 AM   #16
SCOTI
SCOTI's Avatar
Re: New Crossmember
Just making sure you were aware (some people aren't). I guess I've never been lucky enough to run across a truck that had the front end already rebuilt making it worth the effort to swap the whole thing as a unit.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-08-2009, 10:45 PM   #17
Captainfab
60-66 Nut
Re: New Crossmember
Joe, If you are referring to the '73-'87 spindle, then no it won't. However when doing the factory 6 lug swap, you can use either the 5 lug 1500 spindle or the LD2500 spindle (same spindle) and then the lower ball joint for that spindle will fit into a pre '87 C20 lower control arm.
Old 05-08-2009, 11:21 PM   #18
joe231
joe231's Avatar
Re: New Crossmember
Ok, that is what I thought...thanks John
CHEVY ONLY
Old 05-15-2009, 04:01 AM   #19
sams60gmc
sams60gmc's Avatar
Re: New Crossmember
[QUOTE=Tx Firefighter;3297305]For me, the rubber control arm bushings made it more sensible. Replacing the old type screw in metal bushings is very expensive.
hey man I just picked up a cross member today and I want to change all the bushings. Do you have a part number for the kit that you bought? thanks
1960 GMC short fleet, full frame build...
http://67-72chevytrucks.com/vboard/s...d.php?t=329718
sams60gmc is offline   Reply With Quote
Old 05-15-2009, 05:44 AM   #20
Tx Firefighter
Re: New Crossmember
You have two choices, red or black.
Red.....CLICK HERE
Black...CLICK HERE
Both are in stock and ready to ship today.
