push button starter question
i installed a push button starter - i turn the key, push the button, she starts but i cant shift into gear - i'm locked out -
i am not using the neutral safetey switch at all - i ran a jumper wire between the connectors on the NSS but still the same with the engine off i can turn the key into the "1st" position and shift all day long but once the key is in the "2nd" or farthest position before you have to apply pressure for cranking can't shift what should i do to get the column to unlock the shifter when in the 2nd position? thx u geniouses!!! |
Re: push button starter question
what i do when i move cars in a junk yard with no keys is get a breaker bar and put it through the spokes a turn it over as hard as i can to break the lock rod.
if you want the wheeel to be locked i don't know what to do
1974 chevy Cheyenne C10 "The Mutt":4x4 convertion, NP208, 700-R4, stock 350, edelbrock Torker intake, edelbrock 600 CFM carb, duels ![]() 2001 Pontiac Grand Prix GT: 3.8L supercharged, 9.2:1 comprestion, ZZP XP cam, home made intake, 2 1/2" exhuast, 10psi of boost ![]() |
not smart assing....but why did you do that? that's 50's technology.
" Never look up a dead dogs butt." ![]() |
Are we teaching people how to steal trucks now? I have to ask the same question, Why the push button?
What are you working on? Are you having trouble with the gear shifter, or with turning the ignition lock cylinder?
I can still count my vehicles on two... wait three hands. |
#5 | |
I would say that this is a column problem totally unrelated to the starter. If the shifter won't work with the key in the "run" position, it doesn't matter how the engine starts.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
my wording may have came across like i was getting pissy about it or something.i was just wondering like longhair what was his intention? is he trying to get around fixing some problem he doesn't know how to fix.i guess i don't get what he's trying to accomplish.
lol - i'm just retarded...i fingered it out - i replaced the ignition switch trying to troubleshoot another prob and must not have set the "rod" correctly....anyway...i'm halfway in the middle of a new wiring harness so i just bought a $10 push button to wire it up real quick....anyways thx
JL |
